Cortex-A55(ARMv8.2-A) source code debugging method
Hello Folks,
I want to debug the Cortex-A55 (ARMv8.2-A) source code using Arm DS-5 v5.29.3.
The build has completed successfully, and when debugging is specified with arm-none-eabi-gdb.exe in the debug configuration, the following error message is displayed and debugging cannot be started. What could be the cause?
The debug configuration is using C/C++ Remote Application.
The compiler I am using is ARM Compiler 6
I get a similar error on ARM DS 2022.2.
Cortex-M3 (ARMv7) can be source code debugged by the above method.
>Error in final launch sequence
>Failed to execute MI command:
>-file-exec-and-symbols C:/Users/giorno2001/Documents/work/sw/startup_Cortex-A55_Cortex-A75/sample.axf
>Error message from debugger back end:
>"0a3af8a4s": not in executable format: file format not recognized
GDB uses:
C:\arm-gnu-toolchain-12.2.mpacbti-rel1-mingw-w64-i686-arm-none-eabi\bin\arm-none-eabi-gdb.exe
C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2021.07\bin\arm-none-eabi-gdb.exe
C:\Program Files (x86)\GNU Tools ARM Embedded\6 2017-q1-update\bin\arm-none-eabi-gdb.exe
C:\Program Files (x86)\GNU Tools ARM Embedded\9 2019-q4-major\bin\arm-none-eabi-gdb.exe
C:\Users\giorno2001\Downloads\gcc-arm-10.3-2021.07-mingw-w64-i686-arm-none-eabi.tar\gcc-arm-10.3-2021.07-mingw-w64-i686-arm-none-eabi\bin\arm-none-eabi-gdb.exe
Or is it a makefile setting error?
The build environment uses the following, and the makefile is not edited.
"C:\Program Files\DS-5 v5.29.3\examples\Bare-metal_examples_Armv8.zip"
0
