I tried using the getenv to read the CWD inside the FVP , but its returning NULL , I tried passing the in the arguments , environment tab in debug configutation which dint work out , How to fetch the absoulte path inside the baremetal application in FVP
i had also tried passing the absolute path through CMD , "-C cluster0.cpu0.semihosting-cmd_line=" , but is there a way to set the CWD through this parameter
cluster0.cpu0.semihosting-cmd_line is used to pass arguments to main (argv).
Depending on which FVP you are using, there should be a parameter of the form cluster.cpu.semihosting-cwd.
Run "fvp_executable --list-params > parameters.txt" to see all, as well as an explanation of their use.
i had seen this cluster.cpu.semihosting-cwd from the list as well , the problem is to fetch the aboslute path inside the application since getcwd doesnt work for baremetal cases.
