sys path headers are missing in IDE
I wasn't able to include the <sys/stat.h> in the IDE , i was able to override this error by adding the "/usr/include" and $PATH variables under the " project->properties-->path and symbols-> add " , but it lead to other miscellaneous errors as below ,  How to add system header files under this environment
3:46:14 **** Build of configuration Default for project sve_array_sum ****
make all
Building file: ../iohelper.cpp
Invoking: Arm C Compiler 6
armclang --target=aarch64-arm-none-eabi -march=armv8-a+crypto+sve -fvectorize -I"/opt/arm/developmentstudio-2022.2/sw/../sw/ARMCompiler6.19/bin /opt/arm/developmentstudio-2022.2/sw/../bin /opt/arm/developmentstudio-2022.2/bin /opt/arm/developmentstudio-2022.2/sw/java/bin /sbin /bin /usr/bin /usr/local/bin /snap/bin /opt/mellanox/doca/tools/ /opt/mellanox/grpc/bin /opt/mellanox/doca/tools/ /opt/mellanox/grpc/bin" -I/usr/include/ -O1 -g -fno-inline-functions -msve-vector-bits=512 -MD -MP -c -o "iohelper.o" "../iohelper.cpp"
armclang: warning: Your license for feature ds_suite_eval will expire in 14 days [-Wlicense-management]
armclang: warning: Your license for feature ds_compiler_eval20222 will expire in 14 days [-Wlicense-management]
In file included from ../iohelper.cpp:1:
In file included from ../iohelper.h:9:
In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/algorithm:1709:
In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__debug:15:
/opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/cstddef:46:5: error: <cstddef> tried including <stddef.h> but didn't find libc++'s <stddef.h> header. This usually means that your header search paths are not configured properly. The header search paths should contain the C++ Standard Library headers before any C Standard Library, and you are probably using compiler flags that make that not be the case.
# error <cstddef> tried including <stddef.h> but didn't find libc++'s <stddef.h> header. \
/opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/cstddef:59:9: error: no member named 'nullptr_t' in the global namespace
using ::nullptr_t;
full logs are attached
  • 3:46:14 **** Build of configuration Default for project sve_array_sum ****
    make all
    using ::nullptr_t;
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__debug:16:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/type_traits:456:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__type_traits/is_compound.h:14:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__type_traits/is_fundamental.h:14:
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__type_traits/is_null_pointer.h:24:49: error: use of undeclared identifier 'nullptr_t'; did you mean 'nullptr'?
    template <> struct __is_nullptr_t_impl<nullptr_t> : public true_type {};
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__type_traits/is_null_pointer.h:24:49: error: template argument for template type parameter must be a type
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__type_traits/is_null_pointer.h:23:17: note: template parameter is declared here
    template <class _Tp> struct __is_nullptr_t_impl : public false_type {};
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/type_traits:537:
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/cstdint:149:5: error: <cstdint> tried including <stdint.h> but didn't find libc++'s <stdint.h> header. This usually means that your header search paths are not configured properly. The header search paths should contain the C++ Standard Library headers before any C Standard Library, and you are probably using compiler flags that make that not be the case.
    # error <cstdint> tried including <stdint.h> but didn't find libc++'s <stdint.h> header. \
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/algorithm:1711:
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/cstring:65:5: error: <cstring> tried including <string.h> but didn't find libc++'s <string.h> header. This usually means that your header search paths are not configured properly. The header search paths should contain the C++ Standard Library headers before any C Standard Library, and you are probably using compiler flags that make that not be the case.
    # error <cstring> tried including <string.h> but didn't find libc++'s <string.h> header. \
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/algorithm:1715:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__algorithm/adjacent_find.h:14:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__algorithm/iterator_operations.h:15:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__iterator/advance.h:20:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__utility/unreachable.h:13:
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/cstdlib:90:5: error: <cstdlib> tried including <stdlib.h> but didn't find libc++'s <stdlib.h> header. This usually means that your header search paths are not configured properly. The header search paths should contain the C++ Standard Library headers before any C Standard Library, and you are probably using compiler flags that make that not be the case.
    # error <cstdlib> tried including <stdlib.h> but didn't find libc++'s <stdlib.h> header. \
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/algorithm:1749:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__algorithm/inplace_merge.h:27:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__memory/temporary_buffer.h:17:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/new:95:
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/exception:193:45: error: field has incomplete type 'exception_ptr'
    _LIBCPP_INLINE_VISIBILITY exception_ptr(nullptr_t) _NOEXCEPT : __ptr_() {}
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/exception:188:24: note: definition of 'std::exception_ptr' is not complete until the closing '}'
    class _LIBCPP_TYPE_VIS exception_ptr
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/exception:193:5: error: '__abi_tag__' attribute only applies to structs, variables, functions, and namespaces
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__config:692:37: note: expanded from macro '_LIBCPP_INLINE_VISIBILITY'
    # define _LIBCPP_INLINE_VISIBILITY _LIBCPP_HIDE_FROM_ABI
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__config:676:26: note: expanded from macro '_LIBCPP_HIDE_FROM_ABI'
    __attribute__((__abi_tag__(_LIBCPP_TOSTRING(_LIBCPP_VERSIONED_IDENTIFIER))))
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/exception:193:55: error: expected ';' at end of declaration list
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/new:123:12: error: unknown type name '_ARMABI'
    extern "C" _ARMABI int posix_memalign(void**, size_t, size_t);
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__algorithm/inplace_merge.h:28:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__memory/unique_ptr.h:21:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__memory/compressed_pair.h:17:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/tuple:224:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/compare:145:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__compare/compare_partial_order_fallback.h:13:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__compare/partial_order.h:14:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__compare/weak_order.h:14:
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__compare/strong_order.h:18:
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/cmath:316:5: error: <cmath> tried including <math.h> but didn't find libc++'s <math.h> header. This usually means that your header search paths are not configured properly. The header search paths should contain the C++ Standard Library headers before any C Standard Library, and you are probably using compiler flags that make that not be the case.
    # error <cmath> tried including <math.h> but didn't find libc++'s <math.h> header. \
    In file included from /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/tuple:1823:
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/typeinfo:249:14: error: cast from pointer to smaller type '__type_name_t' (aka 'unsigned int') loses information
    return reinterpret_cast<__type_name_t>(__v);
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__memory/unique_ptr.h:172:3: error: non-static data member cannot be constexpr; did you intend to make it const?
    _LIBCPP_CONSTEXPR unique_ptr(nullptr_t) _NOEXCEPT : __ptr_(__value_init_tag(), __value_init_tag()) {}
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__config:457:31: note: expanded from macro '_LIBCPP_CONSTEXPR'
    # define _LIBCPP_CONSTEXPR constexpr
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__memory/unique_ptr.h:172:32: error: member 'nullptr_t' declared as a template
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__memory/unique_ptr.h:172:42: error: expected ';' at end of declaration list
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__memory/unique_ptr.h:249:81: error: unknown type name 'nullptr_t'
    _LIBCPP_INLINE_VISIBILITY _LIBCPP_CONSTEXPR_SINCE_CXX23 unique_ptr& operator=(nullptr_t) _NOEXCEPT {
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__memory/unique_ptr.h:370:3: error: non-static data member cannot be constexpr; did you intend to make it const?
    /opt/arm/developmentstudio-2022.2/sw/ARMCompiler6.19/bin/../include/libcxx/__memory/unique_ptr.h:370:32: error: member 'nullptr_t' declared as a template
    fatal error: too many errors emitted, stopping now [-ferror-limit=]
    20 errors generated.
    make: *** [subdir.mk:26: iohelper.o] Error 1
    "make all" terminated with exit code 2. Build might be incomplete.
    13:46:15 Build Failed. 21 errors, 2 warnings. (took 764ms)
  • Hi there, I have moved your question the Arm Development Studio forum. Many thanks.
  • Hi Thanujvashan
    My name is Stephen and I work at Arm.
    Arm Compiler 6.19 (as provided in Arm DS 2022.2) is a C/C++ compiler intended for bare-metal and embedded applications.
    By contrast, <sys/stat.h> is POSIX.  Arm Compiler 6.19 does not provide sys/stat.h, which explains why your build is failing.
    Are you trying to build a Linux application?  If so, you need to use GCC rather than Arm Compiler 6.
    You can download GCC for AArch64 GNU/Linux target (aarch64-none-linux-gnu) and other variants from https://developer.arm.com/downloads/-/arm-gnu-toolchain-downloads
    Hope this helps,
    Stephen
  • Thanks for the answer , currently am working on baremetal applications over Neoverse N2 model , Could you confirm me if  these headers will be working in linux application over N2 FVP models
  • Yes, GCC 12.2.Rel1 for AArch64 GNU/Linux target (aarch64-none-linux-gnu) contains <sys/stat.h>.
    You can download it from https://developer.arm.com/downloads/-/arm-gnu-toolchain-downloads
    Stephen
