I would like to shortly understand the differences between the the ".rteconfig->Device and Board->Security Mode" values:
and how it effects the project per specific option
Thanks in advanced,Ronen
Hi Ronen,
It defines whether or not this code resides in secure or non-secure world. This is described here:https://developer.arm.com/documentation/100748/0619/Security-features-supported-in-Arm-Compiler-for-Embedded/Overview-of-building-Secure-and-Non-secure-images-with-the-Armv8-M-Security-Extension
It is controlled by the -mcmse compiler option:https://developer.arm.com/documentation/101754/0619/armclang-Reference/armclang-Command-line-Options/-mcmse
Ronan
Thanks Ronan.
Another question pls:My linker command does not include the option -mcmse.In that case would it be correct to say that my build image runs in a "Non-secure" state?
-mcmse
Thanks,Ronen
It is a _compiler_ option rather than linker.
If you are concerned... It may be better to think that the code is not making use of the Trustzone-M functionality of Armv8-M, rather than it simply being 'non-secure'!
Oops, sorry i meant for a compiler option.Yes, this is much better to understand that my code "is not making use of the Trustzone-M functionality".
Thanks again,Ronen
