I would like to avoid the "Tutorials and Videos" window during Arm DS startup, do you know how to do so?
Thanks,Ronen
Hi Ronen, after closing, it should not reappear.
Indeed from the screenshot, it seems you have it open multiple times, which should not be possible. In Window > Preferences you can disable automatic updates of the view (as well as the prompt for the feedback survey).
Between this and other issues you are having with the FVP as reported on another thread, I wonder if your installation is corrupt somehow (??).
What host are you running on?https://developer.arm.com/documentation/101469/2022-2/Installing-and-configuring-Arm-Development-Studio/Hardware-and-host-platform-requirements
Hi Ronan,
Do you recommend on uninstall my DS and reinstall just to be on the safe side?
>>What host are you running on?I'm using Microsoft Windows 10 Pro
Finally I've changed the model parameters per your recomendation - that worked.
