ARM-DS5 License issue.
I had updated the license according to the "ug_soc_eds.pdf". But a Flexnet license error is thrown.
Could you please guide in solving the issue.
it looks like you are trying to use DS-5 from Windows Terminal Service (Remote Desktop). Unfortunately this is not allowed with Node-locked licenses: http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.faqs/12518.html
Can you try to run the same connection directly from the machine with DS-5 installed?
Best Regards,
Stefano
As you said, If we use the machine directly,,(without remote desktop login), the software is working fine without the license error.
Thanks for your valuable suggestion.
I have a new query..,
As it is common machine, it is difficult to use that machine directly, So we had planned to shift the generated license to another machine. Whether we can shift the license installed in one PC to another.
you would need to rehost your license to change the hostid. You can rehost your license at this link: https://silver.arm.com
From there you can do “Software Licenses” -> “Licensing” -> “Rehost”.
Hope this helps.
Best Regards,Stefano
