Finally have typed a first ASM test prog that compiles.
If I start the debugger msg: 'ULINK not found'. I have
no ULINK and want to simulate. HOW?
Hello chip,
can you check your target settings? As simulation is not very often used these days, the default is to use debugging on an actual target. Go to Project --> Options for Target and click on the Debug tab:
Click Use Simulator on the left hand side to use simulation instead. Please be aware that nowadays not all peripherals of all chips can be simulated. Please check this page: simulation.
Kind regards,
Christopher
