I had a capture file that is around 114 GB (because I use ultral high resolution), but I only interest about 30s range of the performance data.
So I want to delete other part of data which can speed up streamline.
Hi iculi,Could we know more about your use case? Is there a reason why you need the ultra-high resolution?Sorry, we don't have a means to trim to a desired interval.Andrew
Thanks for your reply. I use ultra high to show more detailed data. The use case is I only want to measure some specific scenario.
I just find a way to only capture what I want as I asked in Can streamline start capture with delay? - Arm Development Studio forum - Support forums - Arm Community and since I already get answer from that question, I do not need the trim the data now.
Just to be clear on this one - for the Mali counter data the sample rate is always 1ms. High and Ultra high analysis do more fine grained binning, but this is only for visualization. The counter data is still 1ms samples, and is just interpolated between the two nearest samples.
Thanks peter! I will use normal mode then.
Hi Peter, I noticed the normal sample rate is 1ms.
What's the High sample rate is? And if I want to use High sample rate, what's the resolution mode is recommendated? Thanks~
