In order to introduce my issue, my goal is to get 2 similar projects, one compiled by Arm Compiler for Embedded 6 and the other by GCC, both on a FVP Cortex R-52 target.
I chose to build the project on the example available when installing Arm Development Studio named startup_Cortex-R52.
Concerning the Arm Compiler part I have no issues, project works fine as I did not change anything. So I tried to build my second project, compiled by GCC based on the startup_Cortex-R52 example.
I added the GCC 10.3.1 toolchain to Arm Developement Studio and choosed this toolchain in the Tool Chain Editor of my project. I have also set up my project by giving these options in project properties for both GCC Compiler and Assembler : -mcpu=cortex-r52 -mfpu=neon-fp-armv8 -mfloat-abi=hard
Errors occur when I try to build the project and specially in the startup.s file are related to Assembler messages :
I am wondering why I faced this issues as the target is the same and Assembler language too.
If someone can help me to resolve this issue I would be grateful.
Regards, Enzo
