Having a bit of an issue when trying to get the 30 day license for ARM studio, when trying to login I'm met with this issue; I've tried restarting the program as well as resetting my password already. Any help would be appreciated.
Can confirm, same issue here. Any help?
Hello, the system was under maintenance. Please can you try again?
Issue still persists.
The issue still persists on my end.
Facing the same issue. Cannot compile the program without this.
Same problem here. No go.
We believe the issues with generating licenses has been resolved.
If you continue to see issues, please raise a support case from the above support menu.
