ARM DS slow connection to Fast Model
Hello
on the same Linux RH7 machine, it happens that the performances of ARM DS when connecting the debugger to a waiting Virtual Platform  Fast Model (using CADI)  are very random, and often, it takes 3-4 mns to
establish the connection. Sometimes, it takes only a few seconds.But most of the time, it's too slow.
I don't understand why there can be so much difference in performances of connection to a virtual platform. What can I do when ARM DS takes too much time to connect to a Virtual Platform ?
Best regards
Frederic Huguet
  • Hi Frederic
    The variations you see might be related to licensing, or (I think more likely in this case) usage of ports.
    As a first step, try launching the model directly on the command-line outside of Arm DS.  If the model launches quickly and consistently, that would rule-out problems with obtaining a license.
    The Arm DS Debugger uses some default ports to connect to an FVP model.  If some other applications are using those ports, the debugger can spend a long time scanning for other (free) ports.  Try explicitly specifying a non-default port in the debug launcher on which to host the CADI server.
    Hope this helps
    Stephen
  • Hello Stephen,
    many thanks for your question. Could you please tell me how to configure the ^ports used for the debugger connection to the VP ? That is, where in the ARM DS is located the option to be used ?
    This is not very clear on my side ....
    Best Regards
    Frederic
  • Hi again,
    Is there a particular reason why you are using CADI?  "Iris" supersedes CADI, and is now the default in Arm DS Debugger.
    You can launch a model with, for example:
     ./FVP_Base_Cortex-A53x1 --iris-server --print-port-number
    "--print-port-number" reports the port number that the Iris server is listening to, for example:
    Iris server started listening to port 7100
    If that port is already in use, the next port is selected, for example, 7101.
    Make a note of that port number.
    Then, in the debug launch dialog, you can specify the same port number:
    The FVP models also support:
    --iris-port-range MIN:MAX
    Set the range of ports to scan when starting an Iris server. The first available port found will be used.
    and
    --iris-port PORT
    Set a specific port to use for the Iris server.
    Stephen
