Manipulate Ram in an LPC4078
Hello together,
I have an LPC4078. I made measurements with it and everything goes into the RAM. Now I want to manipulate the RAM. Is there a pointer for that? Is the any other possibility?
Thank you and greetings
Chris
  • Hi Chris
    My name is Stephen and I work at Arm.
    Glad to hear you are making progress with your Cortex-M4-based project.  Are you using Arm Development Studio?
    I'm not sure what you mean by "manipulate the RAM".  Please can you explain what you are trying to achieve?
    Stephen
  • Hey Stephen,
    I just saw that I am in the wrong forum. No I don't use the Arm Developement studio.
    I want to alter what is written in the ram or move it from one point to another. Basically I am searching for the pointer which one I can do that. Or is that not possible?
    Thanks in advance.
  • Pointers are just numbers.
    uint32_t *src = (uint32_t) 0x20000000;
    uint32_t *dst = (uint32_t) 0x20010000;
    uint32_t temp = dest[100];  // save original dest word 100
    memcpy(dst, src, 32768); // copy 32k bytes from start of RAM to later in RAM.
    dest[100] = temp;  // restore that one word to old value
    I believe that all Cortex-M processors have their internal RAM at 0x20000000.
    You must of course be careful not to overwrite RAM that is already in use by other code.
