I met an issue when I do profile with DS, the number and instructions and L1/L2 cache is zero.
the warning info is
CONFIG_HW_PERF_EVENTS flag is yes. Any suggestions ?
$ zcat /proc/config.gz | grep CONFIG_HW_PERF_EVENTS
CONFIG_HW_PERF_EVENTS=y
Any help? thanks~
Is the device trusted firmware / hypervisor configured to allow Linux kernel access to PMU counters? As per the description in the warning, if DBGEN is not enabled, the PMU counters will all read as zero.
Do you get any errors showing up in dmesg when you try to enable the counters?
Do you get any errors showing up in the gatord log if you run it with debug logging enabled?
Cheers, Pete
What can you tell us about the board you are using?Can you run gatord -d 1 > log.txt 2>&1to capture a log, then post it here?
[600911.4150835] ERROR: parseCLIArguments(GatorCLIParser.cpp:287): Streamline gatord version 800 (Streamline v8.0) [600911.4164888] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-M3" id="ARMv7M_Cortex_M3" counter_set="DWT" cpuid="0x41c23" pmnc_counters="6" /> [600911.4165614] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-M4" id="ARMv7M_Cortex_M4" counter_set="DWT" cpuid="0x41c24" pmnc_counters="6" /> [600911.4165861] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-M7" id="ARMv7M_Cortex_M7" counter_set="DWT" cpuid="0x41c27" pmnc_counters="6" /> [600911.4166065] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-M33" id="ARMv8M_Cortex_M33" counter_set="DWT" cpuid="0x41d21" pmnc_counters="6" /> [600911.4166271] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-M55" id="ARMv8M_Cortex_M55" counter_set="DWT" cpuid="0x41d22" pmnc_counters="6" /> [600911.4166479] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-R4" id="ARMv7R_Cortex_R4" counter_set="ARMv7R_Cortex_R4" cpuid="0x41c14" pmnc_counters="3" /> [600911.4166679] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-R5" id="ARMv7R_Cortex_R5" counter_set="ARMv7R_Cortex_R5" cpuid="0x41c15" pmnc_counters="3" /> [600911.4166869] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-R7" id="ARMv7R_Cortex_R7" counter_set="ARMv7R_Cortex_R7" cpuid="0x41c17" pmnc_counters="8" /> [600911.4167058] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-R8" id="ARMv7R_Cortex_R8" counter_set="ARMv7R_Cortex_R8" cpuid="0x41c18" pmnc_counters="8" /> [600911.4167437] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-R52" id="ARMv8R_Cortex_R52" counter_set="ARMv8R_Cortex_R52" cpuid="0x41d13" pmnc_counters="4" /> [600911.4167654] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-R52+" id="ARMv8R_Cortex_R52+" counter_set="ARMv8R_Cortex_R52+" cpuid="0x41d16" pmnc_counters="4" /> [600911.4167849] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-R82" id="ARMv8R_Cortex_R82" counter_set="ARMv8R_Cortex_R82" cpuid="0x41d15" pmnc_counters="6" /> [600911.4168041] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="ARM1136" id="ARMv6_1136" counter_set="ARM_ARM11" cpuid="0x41b36" pmnc_counters="3" /> [600911.4168229] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="ARM1156" id="ARMv6_1156" counter_set="ARM_ARM11" cpuid="0x41b56" pmnc_counters="3" /> [600911.4168413] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="ARM1176" id="ARMv6_1176" counter_set="ARM_ARM11" cpuid="0x41b76" pmnc_counters="3" /> [600911.4168596] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="ARM11MPCore" id="ARMv6_11mpcore" counter_set="ARM_ARM11MPCore" cpuid="0x41b02" pmnc_counters="3" /> [600911.4168779] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A5" id="ARMv7_Cortex_A5" counter_set="ARMv7_Cortex_A5" cpuid="0x41c05" pmnc_counters="2" /> [600911.4169141] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A7" id="ARMv7_Cortex_A7" counter_set="ARMv7_Cortex_A7" cpuid="0x41c07" pmnc_counters="4" /> [600911.4169349] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A8" id="ARMv7_Cortex_A8" counter_set="ARMv7_Cortex_A8" cpuid="0x41c08" pmnc_counters="4" /> [600911.4169540] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A9" id="ARMv7_Cortex_A9" counter_set="ARMv7_Cortex_A9" cpuid="0x41c09" pmnc_counters="6" /> [600911.4169727] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A15" id="ARMv7_Cortex_A15" counter_set="ARMv7_Cortex_A15" cpuid="0x41c0f" pmnc_counters="6" /> [600911.4169915] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A17" id="ARMv7_Cortex_A12" counter_set="ARMv7_Cortex_A17" cpuid="0x41c0d" pmnc_counters="6" /> [600911.4170101] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A17" id="ARMv7_Cortex_A17" counter_set="ARMv7_Cortex_A17" cpuid="0x41c0e" pmnc_counters="6" /> [600911.4170330] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A32" id="ARMv8_Cortex_A32" counter_set="ARMv8_Cortex_A32" cpuid="0x41d01" pmnc_counters="6" /> [600911.4170524] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A34" id="ARMv8_Cortex_A34" counter_set="ARMv8_Cortex_A34" cpuid="0x41d02" pmnc_counters="6" /> [600911.4170712] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A35" id="ARMv8_Cortex_A35" counter_set="ARMv8_Cortex_A35" cpuid="0x41d04" pmnc_counters="6" /> [600911.4170905] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A53" id="ARMv8_Cortex_A53" counter_set="ARMv8_Cortex_A53" cpuid="0x41d03" pmnc_counters="6" /> [600911.4171097] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A55" id="ARMv8_Cortex_A55" counter_set="ARMv8_Cortex_A55" cpuid="0x41d05" pmnc_counters="6" /> [600911.4171286] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A57" id="ARMv8_Cortex_A57" counter_set="ARMv8_Cortex_A57" cpuid="0x41d07" pmnc_counters="6" /> [600911.4171474] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A72" id="ARMv8_Cortex_A72" counter_set="ARMv8_Cortex_A72" cpuid="0x41d08" pmnc_counters="6" /> [600911.4171662] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A73" id="ARMv8_Cortex_A73" counter_set="ARMv8_Cortex_A73" cpuid="0x41d09" pmnc_counters="6" /> [600911.4171850] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A75" id="ARMv8_Cortex_A75" counter_set="ARMv8_Cortex_A75" cpuid="0x41d0a" pmnc_counters="6" /> [600911.4172036] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A76" id="ARMv8_Cortex_A76" counter_set="ARMv8_Cortex_A76" cpuid="0x41d0b" pmnc_counters="6" /> [600911.4172681] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A77" id="ARMv8_Cortex_A77" counter_set="ARMv8_Cortex_A77" cpuid="0x41d0d" pmnc_counters="6" /> [600911.4172902] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A78" id="ARMv8_Cortex_A78" counter_set="ARMv8_Cortex_A78" cpuid="0x41d41" pmnc_counters="6" /> [600911.4173104] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A65AE" id="ARMv8_Cortex_A65AE" counter_set="ARMv8_Cortex_A65AE" cpuid="0x41d43" pmnc_counters="6" /> [600911.4173292] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A65" id="ARMv8_Cortex_A65" counter_set="ARMv8_Cortex_A65AE" cpuid="0x41d06" pmnc_counters="6" /> [600911.4173480] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A76AE" id="ARMv8_Cortex_A76AE" counter_set="ARMv8_Cortex_A76" cpuid="0x41d0e" pmnc_counters="6" /> [600911.4173671] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A78AE" id="ARMv8_Cortex_A78AE" counter_set="ARMv8_Cortex_A78" cpuid="0x41d42" pmnc_counters="6" /> [600911.4173860] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A78C" id="ARMv8_Cortex_A78C" counter_set="ARMv8_Cortex_A78" cpuid="0x41d4b" pmnc_counters="6" /> [600911.4174050] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Neoverse-E1" id="ARMv8_Neoverse_E1" counter_set="ARMv8_Neoverse_E1" cpuid="0x41d4a" pmnc_counters="6" /> [600911.4174236] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Neoverse-N1" id="ARMv8_Neoverse_N1" counter_set="ARMv8_Neoverse_N1" cpuid="0x41d0c" pmnc_counters="6" /> [600911.4174427] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Neoverse-N2" id="ARMv8_Neoverse_N2" counter_set="ARMv8_Neoverse_N2" cpuid="0x41d49" pmnc_counters="6" /> [600911.4174620] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Neoverse-V1" id="ARMv8_Neoverse_V1" counter_set="ARMv8_Neoverse_V1" cpuid="0x41d40" pmnc_counters="6" /> [600911.4174817] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-X1" id="ARMv8_Cortex_X1" counter_set="ARMv8_Cortex_X1" cpuid="0x41d44" pmnc_counters="6" /> [600911.4175049] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-X2" id="ARMv8_Cortex_X2" counter_set="ARMv8_Cortex_X2" cpuid="0x41d4c" pmnc_counters="6" /> [600911.4175246] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A510" id="ARMv8_Cortex_A510" counter_set="ARMv8_Cortex_A510" cpuid="0x41d46" pmnc_counters="6" /> [600911.4175439] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Cortex-A710" id="ARMv8_Cortex_A710" counter_set="ARMv8_Cortex_A710" cpuid="0x41d47" pmnc_counters="6" /> [600911.4175627] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="STAR" id="ARMv8M_STAR" counter_set="DWT" cpuid="0x63132" pmnc_counters="6" /> [600911.4175811] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Scorpion" id="ARMv7_Scorpion" counter_set="Scorpion" cpuid="0x5100f" pmnc_counters="4" /> [600911.4175997] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="ScorpionMP" id="ARMv7_Scorpion_MP" counter_set="ScorpionMP" cpuid="0x5102d" pmnc_counters="4" /> [600911.4176197] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Krait" id="ARMv7_Krait" counter_set="Krait" cpuid="0x51049" pmnc_counters="4" /> [600911.4176391] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Kryo Silver" id="ARMv8_Kryo_Silver" counter_set="Other" cpuid="0x51201" pmnc_counters="6" /> [600911.4176579] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Kryo Gold" id="ARMv8_Kryo_Gold" counter_set="Other" cpuid="0x51205" pmnc_counters="6" /> [600911.4176763] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Kryo 250/260/280 Silver" id="ARMv8_Kryo_2x0_Silver" counter_set="ARMv8_Cortex_A53" cpuid="0x51801" pmnc_counters="6" /> [600911.4176953] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Kryo 360/385 Silver" id="ARMv8_Kryo_3x0_Silver" counter_set="ARMv8_Cortex_A55" cpuid="0x51803" pmnc_counters="6" /> [600911.4177145] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Kryo 460/485/495/585 Silver" id="ARMv8_Kryo_4x0_Silver" counter_set="ARMv8_Cortex_A55" cpuid="0x51805" pmnc_counters="6" /> [600911.4177334] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Kryo 260/280 Gold" id="ARMv8_Kryo_2x0_Gold" counter_set="ARMv8_Cortex_A73" cpuid="0x51800" pmnc_counters="6" /> [600911.4177521] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Kryo 360/385 Gold" id="ARMv8_Kryo_3x0_Gold" counter_set="ARMv8_Cortex_A75" cpuid="0x51802" pmnc_counters="6" /> [600911.4177707] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Kryo 460/485/495 Gold" id="ARMv8_Kryo_4x0_Gold" counter_set="ARMv8_Cortex_A76" cpuid="0x51804" pmnc_counters="6" /> [600911.4177895] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Exynos-M1/M2" id="ARMv8_Exynos_M1" counter_set="ARMv8_Exynos_M1" cpuid="0x53001" pmnc_counters="6" /> [600911.4178074] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Exynos-M3" id="ARMv8_Exynos_M3" counter_set="ARMv8_Exynos_M3" cpuid="0x53002" pmnc_counters="6" /> [600911.4178255] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Exynos-M4" id="ARMv8_Exynos_M4" counter_set="Other" cpuid="0x53003" pmnc_counters="6" /> [600911.4178435] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Exynos-M5" id="ARMv8_Exynos_M5" counter_set="Other" cpuid="0x53004" pmnc_counters="6" /> [600911.4178633] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="ThunderX" id="ARMv8_Cavium_Thunder" counter_set="ARMv8_Cavium_Thunder" cpuid="0x430a0" pmnc_counters="6" /> [600911.4179485] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="eMAG" id="ARMv8_Ampere_eMAG" counter_set="ARMv8_Ampere_eMAG" cpuid="0x50000" pmnc_counters="6" /> [600911.4179862] INFO: parseXml(xml/PmuXMLParser.cpp:199): Found <pmu core_name="Nvidia-Denver" id="ARMv8_NVIDIA_Denver" counter_set="Other" cpuid="0x4e000" pmnc_counters="6" /> [600911.4180222] INFO: parseXml(xml/PmuXMLParser.cpp:245): Found <uncore_pmu core_name="CCI_400" id="CCI_400" counter_set="CCI_400" has_cycles_counter="true" pmnc_counters="4" /> [600911.4180490] INFO: parseXml(xml/PmuXMLParser.cpp:245): Found <uncore_pmu core_name="CCI_400_r1" id="CCI_400_r1" counter_set="CCI_400_r1" has_cycles_counter="true" pmnc_counters="4" /> [600911.4180740] INFO: parseXml(xml/PmuXMLParser.cpp:245): Found <uncore_pmu core_name="CCI_500" id="CCI_500" counter_set="CCI_500" has_cycles_counter="false" pmnc_counters="8" /> [600911.4180927] INFO: parseXml(xml/PmuXMLParser.cpp:245): Found <uncore_pmu core_name="ARM_CCN_5XX" id="ccn" counter_set="ARM_CCN_5XX" has_cycles_counter="true" pmnc_counters="8" /> [600911.4181109] INFO: parseXml(xml/PmuXMLParser.cpp:245): Found <uncore_pmu core_name="CMN-600" id="arm_cmn" counter_set="CMN_600" has_cycles_counter="true" pmnc_counters="8" /> [600911.4181296] INFO: parseXml(xml/PmuXMLParser.cpp:245): Found <uncore_pmu core_name="L2C-310" id="l2c_310" counter_set="L2C-310" has_cycles_counter="false" pmnc_counters="2" /> [600911.4184673] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'software' for 'arm_dsu_%d' [600911.4184907] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'cs_etm' for 'arm_dsu_%d' [600911.4185079] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'breakpoint' for 'arm_dsu_%d' [600911.4185243] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'llcc-pmu' for 'arm_dsu_%d' [600911.4185408] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'tracepoint' for 'arm_dsu_%d' [600911.4185569] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'armv8_pmuv3' for 'arm_dsu_%d' [600911.4185751] INFO: parseXml(xml/PmuXMLParser.cpp:300): No matching devices for wildcard <uncore_pmu core_name="DSU" id="arm_dsu_%d" counter_set="DSU" has_cycles_counter="true" pmnc_counters="6" /> [600911.4188203] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'software' for 'smmuv3_pmcg_%s' [600911.4188564] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'cs_etm' for 'smmuv3_pmcg_%s' [600911.4188735] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'breakpoint' for 'smmuv3_pmcg_%s' [600911.4188896] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'llcc-pmu' for 'smmuv3_pmcg_%s' [600911.4189054] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'tracepoint' for 'smmuv3_pmcg_%s' [600911.4189214] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'armv8_pmuv3' for 'smmuv3_pmcg_%s' [600911.4189386] INFO: parseXml(xml/PmuXMLParser.cpp:300): No matching devices for wildcard <uncore_pmu core_name="System MMU v3" id="smmuv3_pmcg_%s" counter_set="SMMUv3" has_cycles_counter="false" pmnc_counters="64" /> [600911.4191709] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'software' for 'l3c%d' [600911.4191916] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'cs_etm' for 'l3c%d' [600911.4192086] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'breakpoint' for 'l3c%d' [600911.4192250] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'llcc-pmu' for 'l3c%d' [600911.4192409] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'tracepoint' for 'l3c%d' [600911.4192570] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'armv8_pmuv3' for 'l3c%d' [600911.4192743] INFO: parseXml(xml/PmuXMLParser.cpp:300): No matching devices for wildcard <uncore_pmu core_name="L3C" id="l3c%d" counter_set="L3C" has_cycles_counter="true" pmnc_counters="4" /> [600911.4195056] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'software' for 'mc%d' [600911.4195260] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'cs_etm' for 'mc%d' [600911.4195431] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'breakpoint' for 'mc%d' [600911.4195593] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'llcc-pmu' for 'mc%d' [600911.4195750] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'tracepoint' for 'mc%d' [600911.4195907] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'armv8_pmuv3' for 'mc%d' [600911.4196126] INFO: parseXml(xml/PmuXMLParser.cpp:300): No matching devices for wildcard <uncore_pmu core_name="MCU" id="mc%d" counter_set="MCU" has_cycles_counter="true" pmnc_counters="4" /> [600911.4198436] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'software' for 'mcb%d' [600911.4198641] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'cs_etm' for 'mcb%d' [600911.4198808] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'breakpoint' for 'mcb%d' [600911.4198970] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'llcc-pmu' for 'mcb%d' [600911.4199130] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'tracepoint' for 'mcb%d' [600911.4199286] INFO: parseXml(xml/PmuXMLParser.cpp:295): no match 'armv8_pmuv3' for 'mcb%d' [600911.4199461] INFO: parseXml(xml/PmuXMLParser.cpp:300): No matching devices for wildcard <uncore_pmu core_name="MCB" id="mcb%d" counter_set="MCB" has_cycles_counter="true" pmnc_counters="4" /> [600911.4202925] INFO: findTraceFsMount(Tracepoints.cpp:125): Reading /proc/mounts [600911.4211967] INFO: findTraceFsMount(Tracepoints.cpp:130): '/dev/root / ext4 ro,relatime,data=ordered 0 0' [600911.4212188] INFO: findTraceFsMount(Tracepoints.cpp:130): 'devtmpfs /dev devtmpfs rw,relatime,size=3370708k,nr_inodes=842677,mode=755 0 0' [600911.4212321] INFO: findTraceFsMount(Tracepoints.cpp:130): 'sysfs /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0' [600911.4212443] INFO: findTraceFsMount(Tracepoints.cpp:130): 'proc /proc proc rw,relatime 0 0' [600911.4212562] INFO: findTraceFsMount(Tracepoints.cpp:130): 'debugfs /sys/kernel/debug debugfs rw,relatime 0 0' [600911.4212681] INFO: findTraceFsMount(Tracepoints.cpp:130): 'tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0' [600911.4212797] INFO: findTraceFsMount(Tracepoints.cpp:130): 'devpts /dev/pts devpts rw,relatime,gid=5,mode=620,ptmxmode=000 0 0' [600911.4212913] INFO: findTraceFsMount(Tracepoints.cpp:130): 'tmpfs /run tmpfs rw,nosuid,nodev,mode=755 0 0' [600911.4213029] INFO: findTraceFsMount(Tracepoints.cpp:130): 'tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0' [600911.4213145] INFO: findTraceFsMount(Tracepoints.cpp:130): 'cgroup2 /sys/fs/cgroup/unified cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate 0 0' [600911.4213269] INFO: findTraceFsMount(Tracepoints.cpp:130): 'cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd 0 0' [600911.4213387] INFO: findTraceFsMount(Tracepoints.cpp:130): 'bpf /sys/fs/bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 0 0' [600911.4213504] INFO: findTraceFsMount(Tracepoints.cpp:130): 'cgroup /sys/fs/cgroup/net_cls,net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio 0 0' [600911.4213619] INFO: findTraceFsMount(Tracepoints.cpp:130): 'cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0' [600911.4213733] INFO: findTraceFsMount(Tracepoints.cpp:130): 'cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0' [600911.4213847] INFO: findTraceFsMount(Tracepoints.cpp:130): 'cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0' [600911.4213961] INFO: findTraceFsMount(Tracepoints.cpp:130): 'cgroup /sys/fs/cgroup/hugetlb cgroup rw,nosuid,nodev,noexec,relatime,hugetlb 0 0' [600911.4214076] INFO: findTraceFsMount(Tracepoints.cpp:130): 'cgroup /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0' [600911.4214191] INFO: findTraceFsMount(Tracepoints.cpp:130): 'cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0' [600911.4214308] INFO: findTraceFsMount(Tracepoints.cpp:130): 'cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0' [600911.4214423] INFO: findTraceFsMount(Tracepoints.cpp:130): 'cgroup /sys/fs/cgroup/debug cgroup rw,nosuid,nodev,noexec,relatime,debug 0 0' [600911.4214538] INFO: findTraceFsMount(Tracepoints.cpp:130): 'cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0' [600911.4214656] INFO: findTraceFsMount(Tracepoints.cpp:130): 'cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0' [600911.4214771] INFO: findTraceFsMount(Tracepoints.cpp:130): 'tmpfs /etc/machine-id tmpfs ro,mode=755 0 0' [600911.4214886] INFO: findTraceFsMount(Tracepoints.cpp:130): 'hugetlbfs /dev/hugepages hugetlbfs rw,relatime,pagesize=2M 0 0' [600911.4215001] INFO: findTraceFsMount(Tracepoints.cpp:130): 'mqueue /dev/mqueue mqueue rw,nosuid,nodev,noexec,relatime 0 0' [600911.4215116] INFO: findTraceFsMount(Tracepoints.cpp:130): 'fusectl /sys/fs/fuse/connections fusectl rw,nosuid,nodev,noexec,relatime 0 0' [600911.4215232] INFO: findTraceFsMount(Tracepoints.cpp:130): 'configfs /sys/kernel/config configfs rw,nosuid,nodev,noexec,relatime 0 0' [600911.4215346] INFO: findTraceFsMount(Tracepoints.cpp:130): '/dev/sda2 /var ext4 rw,relatime,data=ordered 0 0' [600911.4215459] INFO: findTraceFsMount(Tracepoints.cpp:130): '/dev/sda2 /persist ext4 rw,relatime,data=ordered 0 0' [600911.4215573] INFO: findTraceFsMount(Tracepoints.cpp:130): 'tmpfs /var/volatile tmpfs rw,relatime 0 0' [600911.4215687] INFO: findTraceFsMount(Tracepoints.cpp:130): 'tmpfs /persist/volatile tmpfs rw,relatime 0 0' [600911.4215800] INFO: findTraceFsMount(Tracepoints.cpp:130): '/dev/sda2 /etc/adb_devid ext4 rw,relatime,data=ordered 0 0' [600911.4215912] INFO: findTraceFsMount(Tracepoints.cpp:130): '/dev/sda2 /etc/build.prop ext4 rw,relatime,data=ordered 0 0' [600911.4216026] INFO: findTraceFsMount(Tracepoints.cpp:130): 'overlay /etc/usb overlay rw,relatime,lowerdir=/etc/usb/,upperdir=/var/usb,workdir=/var/.usb-work 0 0' [600911.4216141] INFO: findTraceFsMount(Tracepoints.cpp:130): '/dev/sde5 /bluetooth vfat ro,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro 0 0' [600911.4216256] INFO: findTraceFsMount(Tracepoints.cpp:130): '/dev/sde4 /firmware vfat ro,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro 0 0' [600911.4216371] INFO: findTraceFsMount(Tracepoints.cpp:130): '/dev/sde9 /dsp ext4 ro,relatime,data=ordered 0 0' [600911.4216485] INFO: findTraceFsMount(Tracepoints.cpp:130): '/dev/sda9 /data ext4 rw,nodev,relatime,discard,noauto_da_alloc,data=ordered 0 0' [600911.4216600] INFO: findTraceFsMount(Tracepoints.cpp:130): '/dev/sda9 /home ext4 rw,nodev,relatime,discard,noauto_da_alloc,data=ordered 0 0' [600911.4216715] INFO: findTraceFsMount(Tracepoints.cpp:130): 'adb /dev/usb-ffs/adb functionfs rw,relatime 0 0' [600911.4216829] INFO: findTraceFsMount(Tracepoints.cpp:130): 'binder /dev/binderfs binder rw,relatime,max=1048576,stats=global 0 0' [600911.4216944] INFO: findTraceFsMount(Tracepoints.cpp:130): 'tmpfs /run/user/0 tmpfs rw,nosuid,nodev,relatime,size=705188k,mode=700 0 0' [600911.4217058] INFO: findTraceFsMount(Tracepoints.cpp:130): 'tracefs /sys/kernel/debug/tracing tracefs rw,relatime 0 0' [600911.4217171] INFO: findTraceFsMount(Tracepoints.cpp:144): Found tracefs at '/sys/kernel/debug/tracing' [600911.4233189] INFO: MaliHwCntrDriver(mali_userspace/MaliHwCntrDriver.cpp:20): There are no mali devices to create readers [600911.4250170] INFO: CoreOnliner(linux/CoreOnliner.cpp:21): CoreOnliner(core=0, known=1, online=1, changed=0) [600911.4252733] INFO: CoreOnliner(linux/CoreOnliner.cpp:21): CoreOnliner(core=1, known=1, online=1, changed=0) [600911.4262317] INFO: readCpuMaskFromFile(lib/Utils.cpp:123): Reading cpumask from /sys/devices/system/cpu/cpu1/topology/core_siblings_list [600911.4262755] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 0 to mask [600911.4262906] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 1 to mask [600911.4263031] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 2 to mask [600911.4263149] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 3 to mask [600911.4264108] INFO: readCpuMaskFromFile(lib/Utils.cpp:123): Reading cpumask from /sys/devices/system/cpu/cpu0/topology/core_siblings_list [600911.4264308] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 0 to mask [600911.4264440] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 1 to mask [600911.4264560] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 2 to mask [600911.4264679] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 3 to mask [600911.4263466] INFO: CoreOnliner(linux/CoreOnliner.cpp:21): CoreOnliner(core=3, known=1, online=1, changed=0) [600911.4265409] INFO: CoreOnliner(linux/CoreOnliner.cpp:21): CoreOnliner(core=2, known=1, online=1, changed=0) [600911.4277791] INFO: readCpuMaskFromFile(lib/Utils.cpp:123): Reading cpumask from /sys/devices/system/cpu/cpu2/topology/core_siblings_list [600911.4278634] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 0 to mask [600911.4278901] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 1 to mask [600911.4279112] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 2 to mask [600911.4279316] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 3 to mask [600911.4279503] INFO: readCpuMaskFromFile(lib/Utils.cpp:123): Reading cpumask from /sys/devices/system/cpu/cpu3/topology/core_siblings_list [600911.4279889] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 0 to mask [600911.4280120] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 1 to mask [600911.4280329] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 2 to mask [600911.4280532] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 3 to mask [600911.4288160] INFO: CoreOnliner(linux/CoreOnliner.cpp:21): CoreOnliner(core=4, known=1, online=1, changed=0) [600911.4291659] INFO: CoreOnliner(linux/CoreOnliner.cpp:21): CoreOnliner(core=6, known=1, online=1, changed=0) [600911.4294088] INFO: CoreOnliner(linux/CoreOnliner.cpp:21): CoreOnliner(core=5, known=1, online=1, changed=0) [600911.4296902] INFO: CoreOnliner(linux/CoreOnliner.cpp:21): CoreOnliner(core=7, known=1, online=1, changed=0) [600911.4305336] INFO: readCpuMaskFromFile(lib/Utils.cpp:123): Reading cpumask from /sys/devices/system/cpu/cpu4/topology/core_siblings_list [600911.4305657] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 4 to mask [600911.4305756] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 5 to mask [600911.4305833] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 6 to mask [600911.4311934] INFO: readCpuMaskFromFile(lib/Utils.cpp:123): Reading cpumask from /sys/devices/system/cpu/cpu5/topology/core_siblings_list [600911.4312113] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 4 to mask [600911.4312206] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 5 to mask [600911.4312283] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 6 to mask [600911.4808236] INFO: readCpuMaskFromFile(lib/Utils.cpp:123): Reading cpumask from /sys/devices/system/cpu/cpu6/topology/core_siblings_list [600911.4808757] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 4 to mask [600911.4808817] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 5 to mask [600911.4808856] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 6 to mask [600911.5010782] INFO: readCpuMaskFromFile(lib/Utils.cpp:123): Reading cpumask from /sys/devices/system/cpu/cpu7/topology/core_siblings_list [600911.5011292] INFO: readCpuMaskFromFile(lib/Utils.cpp:164): Adding cpu 7 to mask [600911.5017689] INFO: readCpuInfo(CpuUtils.cpp:286): Read CPU 0 CPUID from MIDR_EL1 -> 0x51805 [600911.5017868] INFO: readCpuInfo(CpuUtils.cpp:286): Read CPU 1 CPUID from MIDR_EL1 -> 0x51805 [600911.5017908] INFO: readCpuInfo(CpuUtils.cpp:286): Read CPU 2 CPUID from MIDR_EL1 -> 0x51805 [600911.5020643] INFO: readCpuInfo(CpuUtils.cpp:286): Read CPU 3 CPUID from MIDR_EL1 -> 0x51805 [600911.5020718] INFO: readCpuInfo(CpuUtils.cpp:286): Read CPU 4 CPUID from MIDR_EL1 -> 0x51804 [600911.5020752] INFO: readCpuInfo(CpuUtils.cpp:286): Read CPU 5 CPUID from MIDR_EL1 -> 0x51804 [600911.5020784] INFO: readCpuInfo(CpuUtils.cpp:286): Read CPU 6 CPUID from MIDR_EL1 -> 0x51804 [600911.5020817] INFO: readCpuInfo(CpuUtils.cpp:286): Read CPU 7 CPUID from MIDR_EL1 -> 0x51804 [600911.5021736] INFO: readCpuInfo(CpuUtils.cpp:289): Read CPU 0 CLUSTER 0 [600911.5021854] INFO: readCpuInfo(CpuUtils.cpp:289): Read CPU 1 CLUSTER 0 [600911.5021887] INFO: readCpuInfo(CpuUtils.cpp:289): Read CPU 2 CLUSTER 0 [600911.5021919] INFO: readCpuInfo(CpuUtils.cpp:289): Read CPU 3 CLUSTER 0 [600911.5021949] INFO: readCpuInfo(CpuUtils.cpp:289): Read CPU 4 CLUSTER 1 [600911.5021980] INFO: readCpuInfo(CpuUtils.cpp:289): Read CPU 5 CLUSTER 1 [600911.5022011] INFO: readCpuInfo(CpuUtils.cpp:289): Read CPU 6 CLUSTER 1 [600911.5022041] INFO: readCpuInfo(CpuUtils.cpp:289): Read CPU 7 CLUSTER 2 [600911.5022071] INFO: readCpuInfo(CpuUtils.cpp:292): Read CLUSTER 0 CPUIDs: [600911.5022102] INFO: readCpuInfo(CpuUtils.cpp:294): 0x51805 [600911.5022137] INFO: readCpuInfo(CpuUtils.cpp:292): Read CLUSTER 1 CPUIDs: [600911.5022168] INFO: readCpuInfo(CpuUtils.cpp:294): 0x51804 [600911.5022198] INFO: readCpuInfo(CpuUtils.cpp:292): Read CLUSTER 2 CPUIDs: [600911.5022228] INFO: readCpuInfo(CpuUtils.cpp:294): 0x51804 [600911.5025758] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: Processor : AArch64 Processor rev 14 (aarch64) [600911.5025843] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: processor : 0 [600911.5025900] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: BogoMIPS : 38.40 [600911.5025935] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp [600911.5025969] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU implementer : 0x51 [600911.5026005] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU architecture: 8 [600911.5026038] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU variant : 0xd [600911.5026070] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU part : 0x805 [600911.5026104] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU revision : 14 [600911.5026135] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: [600911.5026167] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: processor : 1 [600911.5026199] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: BogoMIPS : 38.40 [600911.5026233] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp [600911.5026265] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU implementer : 0x51 [600911.5026297] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU architecture: 8 [600911.5026333] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU variant : 0xd [600911.5026365] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU part : 0x805 [600911.5026398] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU revision : 14 [600911.5026431] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: [600911.5026462] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: processor : 2 [600911.5026494] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: BogoMIPS : 38.40 [600911.5026526] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp [600911.5026559] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU implementer : 0x51 [600911.5026592] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU architecture: 8 [600911.5026651] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU variant : 0xd [600911.5026685] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU part : 0x805 [600911.5026719] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU revision : 14 [600911.5026751] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: [600911.5026783] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: processor : 3 [600911.5026816] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: BogoMIPS : 38.40 [600911.5026849] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp [600911.5026883] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU implementer : 0x51 [600911.5026918] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU architecture: 8 [600911.5026951] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU variant : 0xd [600911.5026984] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU part : 0x805 [600911.5027018] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU revision : 14 [600911.5027050] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: [600911.5027083] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: processor : 4 [600911.5027132] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: BogoMIPS : 38.40 [600911.5027167] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp [600911.5027200] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU implementer : 0x51 [600911.5027234] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU architecture: 8 [600911.5027267] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU variant : 0xd [600911.5027300] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU part : 0x804 [600911.5027333] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU revision : 14 [600911.5027366] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: [600911.5027397] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: processor : 5 [600911.5027430] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: BogoMIPS : 38.40 [600911.5027463] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp [600911.5027497] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU implementer : 0x51 [600911.5027531] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU architecture: 8 [600911.5027564] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU variant : 0xd [600911.5027596] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU part : 0x804 [600911.5027630] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU revision : 14 [600911.5027668] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: [600911.5027700] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: processor : 6 [600911.5027734] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: BogoMIPS : 38.40 [600911.5027768] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp [600911.5027801] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU implementer : 0x51 [600911.5027835] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU architecture: 8 [600911.5027868] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU variant : 0xd [600911.5027900] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU part : 0x804 [600911.5027934] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU revision : 14 [600911.5027966] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: [600911.5027999] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: processor : 7 [600911.5028032] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: BogoMIPS : 38.40 [600911.5028065] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp [600911.5028119] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU implementer : 0x51 [600911.5028154] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU architecture: 8 [600911.5028186] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU variant : 0xd [600911.5028219] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU part : 0x804 [600911.5028252] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: CPU revision : 14 [600911.5028285] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: [600911.5028317] INFO: parseProcCpuInfo(CpuUtils.cpp:109): cpuinfo: Hardware : Qualcomm Technologies, Inc SA8155P [600911.5028389] INFO: updateCpuIdsFromTopologyInformation(CpuUtils_Topology.cpp:67): CPU 0 is configured to use CPUID 0x51805 [600911.5028435] INFO: updateCpuIdsFromTopologyInformation(CpuUtils_Topology.cpp:67): CPU 1 is configured to use CPUID 0x51805 [600911.5028469] INFO: updateCpuIdsFromTopologyInformation(CpuUtils_Topology.cpp:67): CPU 2 is configured to use CPUID 0x51805 [600911.5028501] INFO: updateCpuIdsFromTopologyInformation(CpuUtils_Topology.cpp:67): CPU 3 is configured to use CPUID 0x51805 [600911.5028534] INFO: updateCpuIdsFromTopologyInformation(CpuUtils_Topology.cpp:67): CPU 4 is configured to use CPUID 0x51804 [600911.5028566] INFO: updateCpuIdsFromTopologyInformation(CpuUtils_Topology.cpp:67): CPU 5 is configured to use CPUID 0x51804 [600911.5028599] INFO: updateCpuIdsFromTopologyInformation(CpuUtils_Topology.cpp:67): CPU 6 is configured to use CPUID 0x51804 [600911.5028631] INFO: updateCpuIdsFromTopologyInformation(CpuUtils_Topology.cpp:67): CPU 7 is configured to use CPUID 0x51804 [600911.5047816] INFO: detect(PrimarySourceProvider.cpp:376): Determining primary source [600911.5048570] INFO: detect(PrimarySourceProvider.cpp:381): Trying perf API as root... [600911.5048802] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:177): Kernel version: 4.14.180 [600911.5052783] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:229): perf_event_paranoid: 3 [600911.5054013] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:261): Have access to tracepoints [600911.5056321] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:338): perf pmu: software [600911.5056703] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:338): perf pmu: cs_etm [600911.5056874] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:338): perf pmu: breakpoint [600911.5057032] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:338): perf pmu: llcc-pmu [600911.5057189] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:338): perf pmu: tracepoint [600911.5057347] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:338): perf pmu: armv8_pmuv3 [600911.5063660] INFO: readCpuMaskFromFile(lib/Utils.cpp:123): Reading cpumask from /sys/bus/event_source/devices/armv8_pmuv3/cpus [600911.5063839] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 0 to mask [600911.5063967] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 1 to mask [600911.5064083] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 2 to mask [600911.5064196] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 3 to mask [600911.5064310] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 4 to mask [600911.5064423] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 5 to mask [600911.5064540] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 6 to mask [600911.5064657] INFO: readCpuMaskFromFile(lib/Utils.cpp:155): Adding cpu 7 to mask [600911.5064780] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:385): ... cpu 0, with cpuid 0x51805 [600911.5064901] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:385): ... cpu 1, with cpuid 0x51805 [600911.5065015] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:385): ... cpu 2, with cpuid 0x51805 [600911.5065128] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:385): ... cpu 3, with cpuid 0x51805 [600911.5065242] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:385): ... cpu 4, with cpuid 0x51804 [600911.5065353] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:385): ... cpu 5, with cpuid 0x51804 [600911.5065464] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:385): ... cpu 6, with cpuid 0x51804 [600911.5065576] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:385): ... cpu 7, with cpuid 0x51804 [600911.5066037] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:447): generic pmu: Kryo 460/485/495/585 Silver [600911.5066305] INFO: detect(linux/perf/PerfDriverConfiguration.cpp:447): generic pmu: Kryo 460/485/495 Gold [600911.5067236] SETUP: detect(linux/perf/PerfDriverConfiguration.cpp:510): No Perf PMUs detected Could not detect any Perf PMUs in /sys/bus/event_source/devices/ but the system contains recognised CPUs. The system may not support perf hardware counters. Check CONFIG_HW_PERF_EVENTS is set and that the PMU is configured in the target device tree. [600911.5068562] INFO: setPerfEventMlockKb(linux/perf/PerfDriverConfiguration.cpp:98): setting property debug.perf_event_mlock_kb to 2052 [600912.5555514] INFO: setPerfEventMlockKb(linux/perf/PerfDriverConfiguration.cpp:111): failed to set property debug.perf_event_mlock_kb to 2052 [600912.5560884] INFO: PerfDriver(linux/perf/PerfDriver.cpp:244): Adding cpu counters (based on cpuid) for Kryo 460/485/495/585 Silver [600912.5561584] INFO: PerfDriver(linux/perf/PerfDriver.cpp:244): Adding cpu counters (based on cpuid) for Kryo 460/485/495 Gold [600912.5573821] INFO: detect(PrimarySourceProvider.cpp:396): ...Success [600912.5574051] SETUP: detect(PrimarySourceProvider.cpp:397): Profiling Source Using perf API for primary data source [600912.5586496] INFO: getStaticTree(xml/EventsXML.cpp:37): Unable to locate events.xml, using default [600912.6234899] INFO: readEvents(linux/perf/PerfDriver.cpp:554): Using perf for ftrace_kmem_kmalloc [600912.6236367] INFO: readEvents(linux/perf/PerfDriver.cpp:554): Using perf for ftrace_ext4_ext4_da_write [600912.6237112] INFO: readInt64FromFile(lib/Utils.cpp:63): Invalid value in file /sys/kernel/debug/tracing/events/f2fs/f2fs_write_end/id: [600912.6237173] INFO: getTracepointId(Tracepoints.cpp:43): Unable to read tracepoint id for f2fs/f2fs_write_end [600912.6237233] SETUP: _getTracepointId(linux/perf/PerfDriver.cpp:202): ftrace_f2fs_f2fs_write is disabled /sys/kernel/debug/tracing/events/f2fs/f2fs_write_end/id was not found [600912.6237847] INFO: readInt64FromFile(lib/Utils.cpp:63): Invalid value in file /sys/kernel/debug/tracing/events/power/clock_set_rate/id: [600912.6237895] INFO: getTracepointId(Tracepoints.cpp:43): Unable to read tracepoint id for power/clock_set_rate [600912.6237942] SETUP: _getTracepointId(linux/perf/PerfDriver.cpp:202): ftrace_power_clock_set_rate is disabled /sys/kernel/debug/tracing/events/power/clock_set_rate/id was not found [600912.6238571] INFO: readEvents(linux/perf/PerfDriver.cpp:554): Using perf for ftrace_block_block_rq_complete [600912.6239194] INFO: readEvents(linux/perf/PerfDriver.cpp:554): Using perf for ftrace_block_block_rq_issue [600912.6239818] INFO: readEvents(linux/perf/PerfDriver.cpp:554): Using perf for ftrace_power_cpu_idle [600912.6273258] INFO: readEvents(FtraceDriver.cpp:419): Not using ftrace for counter ftrace_kmem_kmalloc [600912.6273449] INFO: readEvents(FtraceDriver.cpp:419): Not using ftrace for counter ftrace_ext4_ext4_da_write [600912.6273491] INFO: readEvents(FtraceDriver.cpp:419): Not using ftrace for counter ftrace_f2fs_f2fs_write [600912.6273533] INFO: readEvents(FtraceDriver.cpp:419): Not using ftrace for counter ftrace_power_clock_set_rate [600912.6273573] INFO: readEvents(FtraceDriver.cpp:419): Not using ftrace for counter ftrace_block_block_rq_complete [600912.6273611] INFO: readEvents(FtraceDriver.cpp:419): Not using ftrace for counter ftrace_block_block_rq_issue [600912.6273648] INFO: readEvents(FtraceDriver.cpp:419): Not using ftrace for counter ftrace_power_cpu_idle [600912.6283368] INFO: readEvents(FtraceDriver.cpp:419): Not using ftrace for counter ftrace_kmem_kmalloc [600912.6283485] INFO: readEvents(FtraceDriver.cpp:419): Not using ftrace for counter ftrace_ext4_ext4_da_write [600912.6283524] INFO: readEvents(FtraceDriver.cpp:419): Not using ftrace for counter ftrace_f2fs_f2fs_write [600912.6283563] INFO: readEvents(FtraceDriver.cpp:419): Not using ftrace for counter ftrace_power_clock_set_rate [600912.6283603] INFO: readEvents(FtraceDriver.cpp:419): Not using ftrace for counter ftrace_block_block_rq_complete [600912.6283641] INFO: readEvents(FtraceDriver.cpp:419): Not using ftrace for counter ftrace_block_block_rq_issue [600912.6283679] INFO: readEvents(FtraceDriver.cpp:419): Not using ftrace for counter ftrace_power_cpu_idle Gator ready [600913.3085969] INFO: Sender(Sender.cpp:40): Completed magic sequence [600913.3103612] INFO: getStaticTree(xml/EventsXML.cpp:37): Unable to locate events.xml, using default [600913.3898963] INFO: query(ExternalDriver.cpp:117): Unable to connect, using cached version; size: 0 [600913.3911396] INFO: query(MidgardDriver.cpp:115): Unable to connect to Midgard [600913.3911929] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_ccnt with event (0x11) [600913.3912029] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_system with event (0x0) [600913.3912105] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_user with event (0x0) [600913.3912243] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_ccnt with event (0x11) [600913.3912320] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_system with event (0x0) [600913.3912394] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_user with event (0x0) [600913.3912576] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:137): INVESTIGATE: Received REQUEST_CONFIG command but with length = 1 [600913.4415181] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:123): INVESTIGATE: Received DISCONNECT command but with length = 1 [600913.4415730] INFO: handleDisconnect(StreamlineSetup.cpp:65): Received disconnect command [600913.4462120] INFO: Sender(Sender.cpp:40): Completed magic sequence [600913.4482869] INFO: onChildDeath(armnn/DriverSourceIpc.cpp:304): Detected gator-child has died [600913.4484092] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:137): INVESTIGATE: Received REQUEST_CONFIG command but with length = 1 [600913.4485282] INFO: handleRequestCurrentConfig(main.cpp:311): INVESTIGATE: Received unknown command type COMMAND_REQUEST_CURRENT_CONFIG [600913.4486773] INFO: operator()(armnn/DriverSourceIpc.cpp:298): Finished listening for armnn start/stop messages [600913.4487050] INFO: writeDataParts(Sender.cpp:113): Sending data with length 163 [600913.4492518] INFO: handleSigchld(main.cpp:102): Child process 1291427 terminated normally with status 0 [600914.4564753] INFO: Sender(Sender.cpp:40): Completed magic sequence [600914.4581056] INFO: getStaticTree(xml/EventsXML.cpp:37): Unable to locate events.xml, using default [600914.5193618] INFO: query(ExternalDriver.cpp:117): Unable to connect, using cached version; size: 0 [600914.5209268] INFO: query(MidgardDriver.cpp:115): Unable to connect to Midgard [600914.5210032] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_ccnt with event (0x11) [600914.5210123] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_system with event (0x0) [600914.5210209] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_user with event (0x0) [600914.5210350] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_ccnt with event (0x11) [600914.5210420] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_system with event (0x0) [600914.5210484] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_user with event (0x0) [600914.5210654] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:137): INVESTIGATE: Received REQUEST_CONFIG command but with length = 1 [600914.5745392] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:123): INVESTIGATE: Received DISCONNECT command but with length = 1 [600914.5746960] INFO: handleDisconnect(StreamlineSetup.cpp:65): Received disconnect command [600914.5782399] INFO: Sender(Sender.cpp:40): Completed magic sequence [600914.5811101] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:137): INVESTIGATE: Received REQUEST_CONFIG command but with length = 1 [600914.5812514] INFO: handleRequestCurrentConfig(main.cpp:311): INVESTIGATE: Received unknown command type COMMAND_REQUEST_CURRENT_CONFIG [600914.5813799] INFO: writeDataParts(Sender.cpp:113): Sending data with length 163 [600914.5864398] INFO: onChildDeath(armnn/DriverSourceIpc.cpp:304): Detected gator-child has died [600914.5866604] INFO: operator()(armnn/DriverSourceIpc.cpp:298): Finished listening for armnn start/stop messages [600914.5872080] INFO: handleSigchld(main.cpp:102): Child process 1291430 terminated normally with status 0 [600915.5895139] INFO: Sender(Sender.cpp:40): Completed magic sequence [600915.5917218] INFO: getStaticTree(xml/EventsXML.cpp:37): Unable to locate events.xml, using default [600915.6735547] INFO: query(ExternalDriver.cpp:117): Unable to connect, using cached version; size: 0 [600915.6747083] INFO: query(MidgardDriver.cpp:115): Unable to connect to Midgard [600915.6747459] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_ccnt with event (0x11) [600915.6747554] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_system with event (0x0) [600915.6747626] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_user with event (0x0) [600915.6747761] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_ccnt with event (0x11) [600915.6747840] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_system with event (0x0) [600915.6747914] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_user with event (0x0) [600915.6748124] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:137): INVESTIGATE: Received REQUEST_CONFIG command but with length = 1 [600915.7249031] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:123): INVESTIGATE: Received DISCONNECT command but with length = 1 [600915.7250006] INFO: handleDisconnect(StreamlineSetup.cpp:65): Received disconnect command [600915.7276257] INFO: Sender(Sender.cpp:40): Completed magic sequence [600915.7304770] INFO: onChildDeath(armnn/DriverSourceIpc.cpp:304): Detected gator-child has died [600915.7307852] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:137): INVESTIGATE: Received REQUEST_CONFIG command but with length = 1 [600915.7308112] INFO: handleRequestCurrentConfig(main.cpp:311): INVESTIGATE: Received unknown command type COMMAND_REQUEST_CURRENT_CONFIG [600915.7308494] INFO: operator()(armnn/DriverSourceIpc.cpp:298): Finished listening for armnn start/stop messages [600915.7309222] INFO: writeDataParts(Sender.cpp:113): Sending data with length 163 [600915.7313021] INFO: handleSigchld(main.cpp:102): Child process 1291433 terminated normally with status 0 [600916.7433892] INFO: Sender(Sender.cpp:40): Completed magic sequence [600916.7451859] INFO: getStaticTree(xml/EventsXML.cpp:37): Unable to locate events.xml, using default [600916.8161731] INFO: query(ExternalDriver.cpp:117): Unable to connect, using cached version; size: 0 [600916.8173402] INFO: query(MidgardDriver.cpp:115): Unable to connect to Midgard [600916.8173800] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_ccnt with event (0x11) [600916.8173898] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_system with event (0x0) [600916.8173968] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_user with event (0x0) [600916.8174102] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_ccnt with event (0x11) [600916.8174179] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_system with event (0x0) [600916.8174250] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_user with event (0x0) [600916.8174467] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:137): INVESTIGATE: Received REQUEST_CONFIG command but with length = 1 [600916.8722705] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:123): INVESTIGATE: Received DISCONNECT command but with length = 1 [600916.8723706] INFO: handleDisconnect(StreamlineSetup.cpp:65): Received disconnect command [600916.8758239] INFO: Sender(Sender.cpp:40): Completed magic sequence [600916.8783015] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:137): INVESTIGATE: Received REQUEST_CONFIG command but with length = 1 [600916.8783373] INFO: handleRequestCurrentConfig(main.cpp:311): INVESTIGATE: Received unknown command type COMMAND_REQUEST_CURRENT_CONFIG [600916.8784631] INFO: writeDataParts(Sender.cpp:113): Sending data with length 163 [600916.8840413] INFO: onChildDeath(armnn/DriverSourceIpc.cpp:304): Detected gator-child has died [600916.8845040] INFO: operator()(armnn/DriverSourceIpc.cpp:298): Finished listening for armnn start/stop messages [600916.8859382] INFO: handleSigchld(main.cpp:102): Child process 1291436 terminated normally with status 0 [600917.8858290] INFO: Sender(Sender.cpp:40): Completed magic sequence malloc_consolidate(): invalid chunk size [600917.8928760] INFO: onChildDeath(armnn/DriverSourceIpc.cpp:304): Detected gator-child has died [600917.8933458] INFO: operator()(armnn/DriverSourceIpc.cpp:298): Finished listening for armnn start/stop messages [600917.8939315] INFO: handleSigchld(main.cpp:112): Child process 1291439 was terminated by signal Aborted (6) [600917.9379857] INFO: Sender(Sender.cpp:40): Completed magic sequence [600917.9397485] INFO: getStaticTree(xml/EventsXML.cpp:37): Unable to locate events.xml, using default [600918.0156057] INFO: query(ExternalDriver.cpp:117): Unable to connect, using cached version; size: 0 [600918.0167549] INFO: query(MidgardDriver.cpp:115): Unable to connect to Midgard [600918.0167916] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_ccnt with event (0x11) [600918.0168010] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_system with event (0x0) [600918.0168080] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_user with event (0x0) [600918.0168215] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_ccnt with event (0x11) [600918.0168292] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_system with event (0x0) [600918.0168364] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_user with event (0x0) [600918.0168568] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:137): INVESTIGATE: Received REQUEST_CONFIG command but with length = 1 [600918.0246584] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:123): INVESTIGATE: Received DISCONNECT command but with length = 1 [600918.0247175] INFO: handleDisconnect(StreamlineSetup.cpp:65): Received disconnect command [600918.0284013] INFO: onChildDeath(armnn/DriverSourceIpc.cpp:304): Detected gator-child has died [600918.0286129] INFO: operator()(armnn/DriverSourceIpc.cpp:298): Finished listening for armnn start/stop messages [600918.0290421] INFO: handleSigchld(main.cpp:102): Child process 1291441 terminated normally with status 0 [600918.9116796] INFO: Sender(Sender.cpp:40): Completed magic sequence [600918.9137051] INFO: getStaticTree(xml/EventsXML.cpp:37): Unable to locate events.xml, using default [600918.9946285] INFO: query(ExternalDriver.cpp:117): Unable to connect, using cached version; size: 0 [600918.9957746] INFO: query(MidgardDriver.cpp:115): Unable to connect to Midgard [600918.9958127] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_ccnt with event (0x11) [600918.9958220] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_system with event (0x0) [600918.9958289] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Gold_user with event (0x0) [600918.9958439] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_ccnt with event (0x11) [600918.9958517] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_system with event (0x0) [600918.9958590] INFO: setupCounter(linux/perf/PerfDriver.cpp:763): Configuring perf counter ARMv8_Kryo_4x0_Silver_user with event (0x0) [600918.9958846] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:137): INVESTIGATE: Received REQUEST_CONFIG command but with length = 1 [600919.0505090] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:123): INVESTIGATE: Received DISCONNECT command but with length = 1 [600919.0505799] INFO: handleDisconnect(StreamlineSetup.cpp:65): Received disconnect command [600919.0555361] INFO: Sender(Sender.cpp:40): Completed magic sequence [600919.0578518] INFO: onChildDeath(armnn/DriverSourceIpc.cpp:304): Detected gator-child has died [600919.0583505] INFO: streamlineSetupCommandIteration(StreamlineSetupLoop.cpp:137): INVESTIGATE: Received REQUEST_CONFIG command but with length = 1 [600919.0584535] INFO: handleRequestCurrentConfig(main.cpp:311): INVESTIGATE: Received unknown command type COMMAND_REQUEST_CURRENT_CONFIG [600919.0583721] INFO: operator()(armnn/DriverSourceIpc.cpp:298): Finished listening for armnn start/stop messages [600919.0586953] INFO: writeDataParts(Sender.cpp:113): Sending data with length 163 [600919.0592287] INFO: handleSigchld(main.cpp:102): Child process 1291443 terminated normally with status 0
Hi xiaoyuan from the log, it looks like you are using version 7.9.0 of gatord, but recompiled to report that it is version 8.0.0, presumably so you can use it with a later version of Streamline?
This is not explected to work; please first retry using the binary provided with Streamline 8.0.
Thanks, Ben
