A1616E armcc compile error
I got compile error "Error: A1616E: Instruction, offset, immediate or register combination is not supported by the current instruction set"
For below routine
__asm uint32_t A(void)
    MRS R0, MSP       ====> line pointed by error message
    LDR R0, [R0,#8]
    BX lr
for both Arm compiler 4.1 and 5.06.  What I am missing here?  thanks...
  • Hello, I quickly tested with Arm Compiler 5.06, and was able to build.
    I suspect you have not specified the processor/architecture on the command line - do you have --cpu=Cortex-M3 or similar on the command line?
    Also, please note these are very old compilers, no longer supported. If you are starting a new project, I urge you to move to armclang.
  • Hi Ronan, thanks for looking into it.  My command is as below, in Arm Studio:
    'Building file: ../src/main.c'
    'Invoking: Arm C Compiler for Embedded 5.6.6'
    armcc.exe --cpu=Cortex-R5 --arm --apcs=interwork -O0 -g --md --depend_format=unix_escaped --no_depend_system_headers --depend_dir="src" -c -o "src/main.o" "../src/main.c"
    "..\src\main.c", line 29: Error: A1616E: Instruction, offset, immediate or register combination is not supported by the current instruction set
    29 00000000 MRS R0, MSP
    Btw, if I remove "MSP", and use another special register, such as "SCTLR", it passed build
  • You are building for Cortex-R5, which does not support MSP (Main Stack Pointer).
    MSP is only provided on Cortex-M processors.
