DSTREAM-ST in DS5 Platform Configuration
if i want to use "Platform Configuration" for DSTREAM-ST in DS5,
i recevive this "Scanchain detection failure: Detected number of devices = 1.024, maximum allowed = 1.023. This problem is usually a result of the scanchain not acting correctly when using JTAG scans to count the number of devices."
Can you help me please to resolve this problem.
I want to test Cortex M33 from NXP (MIMXRT685_EVK)
Thank you in advance.
AH
  • Hi there, I have moved your question to the Arm Development Studio forum. Many thanks.
  • Hi Abdelillah
    Sorry to hear that PCE is not auto-detecting this board automatically.
    You don't say which version of DS-5 you are using, but DS-5 has been superseded by Arm Development Studio.
    As a first step, I recommend that you try Arm Development Studio, which has improved auto-detection capabilities.  A free 30-day evaluation is available.  This will also update the DSTREAM-ST firmware.
    If that does not resolve the problem, please open a Support Case using the "Support > Open a Support Case" option at the top of this page, so that Arm support and engineering teams can properly investigate.
    Hope this helps,
    Stephen
  • Hi Stephen,
    thank you for your answer. I use now the ARM Dev. Studio 2021. I have the same problem  after update.
    in DS 5:
    in ARM Dev. Studio 2021:
    i recevive this "Scanchain detection failure: Detected number of devices = 136, maximum allowed = 128. This problem is usually a result of the scanchain not acting correctly when using JTAG scans to count the number of devices."
  • Hi Abdelillah
    Thanks for updating to Arm DS.  Sorry, I don't have access to that board to be able to try it myself, but I'm surprised that you see a different error message with PCE.
    However, you probably don't need to use PCE for the MIMXRT685, because this device is already "known" by the NXP CMSIS Pack - see screenshot.  Please try selecting one of these ready-made configs instead of using PCE?
    Hope this helps,
    Stephen
