I have a DE1-SoC (Cyclone V) board where I am trying to get timer interrupts to work on the HPS. I found an example in the Intel FPGA University Program called "interrupt_example", and when I run it on the Intel FPGA Universioty Program, it runs perfectly.Now I want to transfer this project to ARM DS, but I cannot get it to work because everytime when I am trying to write to the interval timer at address 0xFF202000, the debugger won't proceed. When I try to look in the memory of 0xFF202000 in ARM DS, I also cannot see anything.
I am using the same compiler (GCC C 4.7.3 arm-altera-eabi) and I tried to use the same compiler arguments:
Intel FPGA Monitor Program
rm -f interrupt_example.c.oarm-altera-eabi-gcc -Wall -c -g -O1 -mfloat-abi=soft -march=armv7-a -mtune=cortex-a9 -mcpu=cortex-a9 interrupt_example.c -o interrupt_example.c.orm -f exceptions.c.oarm-altera-eabi-gcc -Wall -c -g -O1 -mfloat-abi=soft -march=armv7-a -mtune=cortex-a9 -mcpu=cortex-a9 exceptions.c -o exceptions.c.orm -f HPS_timer_ISR.c.oarm-altera-eabi-gcc -Wall -c -g -O1 -mfloat-abi=soft -march=armv7-a -mtune=cortex-a9 -mcpu=cortex-a9 HPS_timer_ISR.c -o HPS_timer_ISR.c.orm -f interval_timer_ISR.c.oarm-altera-eabi-gcc -Wall -c -g -O1 -mfloat-abi=soft -march=armv7-a -mtune=cortex-a9 -mcpu=cortex-a9 interval_timer_ISR.c -o interval_timer_ISR.c.orm -f pushbutton_ISR.c.oarm-altera-eabi-gcc -Wall -c -g -O1 -mfloat-abi=soft -march=armv7-a -mtune=cortex-a9 -mcpu=cortex-a9 pushbutton_ISR.c -o pushbutton_ISR.c.orm -f interrupt_example.axf
ARM DS
make all 'Building file: ../interrupt_example/HPS_timer_ISR.c''Invoking: GCC C Compiler 4.7.3 [arm-altera-eabi]'arm-altera-eabi-gcc.exe -Dsoc_cv_av -I"C:\CSA\Baremetal_Hex_Disco\sw\hps\application\inc" -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include/soc_cv_av -O1 -g3 -Wall -c -mfloat-abi=soft -march=armv7-a -mtune=cortex-a9 -mcpu=cortex-a9 -MMD -MP -MF"interrupt_example/HPS_timer_ISR.d" -MT"interrupt_example/HPS_timer_ISR.o" -c -o "interrupt_example/HPS_timer_ISR.o" "../interrupt_example/HPS_timer_ISR.c"'Finished building: ../interrupt_example/HPS_timer_ISR.c'' ''Building file: ../interrupt_example/exceptions.c''Invoking: GCC C Compiler 4.7.3 [arm-altera-eabi]'arm-altera-eabi-gcc.exe -Dsoc_cv_av -I"C:\CSA\Baremetal_Hex_Disco\sw\hps\application\inc" -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include/soc_cv_av -O1 -g3 -Wall -c -mfloat-abi=soft -march=armv7-a -mtune=cortex-a9 -mcpu=cortex-a9 -MMD -MP -MF"interrupt_example/exceptions.d" -MT"interrupt_example/exceptions.o" -c -o "interrupt_example/exceptions.o" "../interrupt_example/exceptions.c"'Finished building: ../interrupt_example/exceptions.c'' ''Building file: ../interrupt_example/interval_timer_ISR.c''Invoking: GCC C Compiler 4.7.3 [arm-altera-eabi]'arm-altera-eabi-gcc.exe -Dsoc_cv_av -I"C:\CSA\Baremetal_Hex_Disco\sw\hps\application\inc" -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include/soc_cv_av -O1 -g3 -Wall -c -mfloat-abi=soft -march=armv7-a -mtune=cortex-a9 -mcpu=cortex-a9 -MMD -MP -MF"interrupt_example/interval_timer_ISR.d" -MT"interrupt_example/interval_timer_ISR.o" -c -o "interrupt_example/interval_timer_ISR.o" "../interrupt_example/interval_timer_ISR.c"'Finished building: ../interrupt_example/interval_timer_ISR.c'' ''Building file: ../interrupt_example/pushbutton_ISR.c''Invoking: GCC C Compiler 4.7.3 [arm-altera-eabi]'arm-altera-eabi-gcc.exe -Dsoc_cv_av -I"C:\CSA\Baremetal_Hex_Disco\sw\hps\application\inc" -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include/soc_cv_av -O1 -g3 -Wall -c -mfloat-abi=soft -march=armv7-a -mtune=cortex-a9 -mcpu=cortex-a9 -MMD -MP -MF"interrupt_example/pushbutton_ISR.d" -MT"interrupt_example/pushbutton_ISR.o" -c -o "interrupt_example/pushbutton_ISR.o" "../interrupt_example/pushbutton_ISR.c"'Finished building: ../interrupt_example/pushbutton_ISR.c'' ''Building file: ../.metadata/.plugins/org.eclipse.cdt.make.core/specs.c''Invoking: GCC C Compiler 4.7.3 [arm-altera-eabi]'arm-altera-eabi-gcc.exe -Dsoc_cv_av -I"C:\CSA\Baremetal_Hex_Disco\sw\hps\application\inc" -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include/soc_cv_av -O1 -g3 -Wall -c -mfloat-abi=soft -march=armv7-a -mtune=cortex-a9 -mcpu=cortex-a9 -MMD -MP -MF".metadata/.plugins/org.eclipse.cdt.make.core/specs.d" -MT".metadata/.plugins/org.eclipse.cdt.make.core/specs.o" -c -o ".metadata/.plugins/org.eclipse.cdt.make.core/specs.o" "../.metadata/.plugins/org.eclipse.cdt.make.core/specs.c"'Finished building: ../.metadata/.plugins/org.eclipse.cdt.make.core/specs.c'' ''Building file: ../main.c''Invoking: GCC C Compiler 4.7.3 [arm-altera-eabi]'arm-altera-eabi-gcc.exe -Dsoc_cv_av -I"C:\CSA\Baremetal_Hex_Disco\sw\hps\application\inc" -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include/soc_cv_av -O1 -g3 -Wall -c -mfloat-abi=soft -march=armv7-a -mtune=cortex-a9 -mcpu=cortex-a9 -MMD -MP -MF"main.d" -MT"main.o" -c -o "main.o" "../main.c"'Finished building: ../main.c'' '
I am also using the same linker arguments:
arm-altera-eabi-gcc -Wl,--defsym -Wl,arm_program_mem=0x40 -Wl,--defsym -Wl,arm_available_mem_size=0x3fffffb8 -Wl,--defsym -Wl,__cs3_stack=0x3ffffff8 -Wl,--section-start -Wl,.vectors=0x0 -T"C:/intelFPGA_lite/17.0/University_Program/Monitor_Program/build/altera-socfpga-hosted-with-vectors.ld" interrupt_example.c.o exceptions.c.o HPS_timer_ISR.c.o interval_timer_ISR.c.o pushbutton_ISR.c.o -o interrupt_example.axf
arm-altera-eabi-gcc -T "C:\intelFPGA_lite\17.0\University_Program\Monitor_Program\build\altera-socfpga-hosted-with-vectors.ld" --exceptions -Wl,--defsym -Wl,arm_program_mem=0x40 -Wl,--defsym -Wl,arm_available_mem_size=0x3fffffb8 -Wl,--defsym -Wl,__cs3_stack=0x3ffffff8 -Wl,--section-start -Wl,.vectors=0x0 -o "Baremetal_Hex_Disco.axf" ./interrupt_example/HPS_timer_ISR.o ./interrupt_example/exceptions.o ./interrupt_example/interval_timer_ISR.o ./interrupt_example/pushbutton_ISR.o ./.metadata/.plugins/org.eclipse.cdt.make.core/specs.o ./main.o
I also tried to use the same preloader, but this does not work out when I am writing the debug script. I am not sure if this is the problem. If this is actually the problem, I would appreciate it if someone can help me writing another debug script, because ARM DS is giving me problems when I try to use u-boot-spl.de1-soc.srec as a preloader.
Preloader information in Intel FPGA Monitor Program
Info: Running Quartus Prime ProgrammerInfo: Version 17.0.0 Build 595 04/25/2017 SJ Lite EditionInfo: Copyright (C) 2017 Intel Corporation. All rights reserved.Info: Your use of Intel Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Intel Program License Info: Subscription Agreement, the Intel Quartus Prime License Agreement,Info: the Intel MegaCore Function License Agreement, or other Info: applicable license agreement, including, without limitation, Info: that your use is for the sole purpose of programming logic Info: devices manufactured by Intel and sold by Intel or its Info: authorized distributors. Please refer to the applicable Info: agreement for further details.Info: Processing started: Sun Feb 07 10:04:39 2021Info: Command: quartus_hps --cable="DE-SoC [USB-1]" -o GDBSERVER --gdbport0=3350 --preloader=C:/intelFPGA_lite/17.0/University_Program/Monitor_Program/arm_tools/u-boot-spl.de1-soc.srec --preloaderaddr=0xffff13a0 --source=C:/Users/red25/Documents/interrupt_example.srecCurrent hardware is: DE-SoC [USB-1]Successfully change hardware frequency to 16MhzFound HPS at device 1Double check JTAG chainHPS Device IDCODE: 0x4BA00477AHB Port is located at port 0APB Port is located at port 1Double check device identification ...>>CPU0 halted at 0x2fa8.>>Resetting HPS.>>Downloading preloader.....>>Program loaded. PC set to program entry (0xFFFF0000)>>Setting vector base address register to: 0xffff0000>>Running preloader..>>Preloader successfully run.>>Downloading user program.>>Program loaded. PC set to program entry (0x0128)>>Setting vector base address register to: 0x0>> Hard breakpoint set.Starting GDB Server.
Debug script in ARM DS
resetwait 5sstopwaitloadfile "$sdir/../../preloader/uboot-socfpga/spl/u-boot-spl" 0x0set semihosting enabled truedeletetbreak spl_boot_devicerunwaitloadfile "$sdir/../Debug/Baremetal_Hex_Disco.axf" 0x0start
The disassembly of the code where the 0xFF202000 is being written also looks identical:
I tried everything which I could think of now. I really hope someone can help me. Thank you in advance.
Hi, my name is Stephen and I work for Arm.I'm not very familiar with the Cyclone V board, but I might be offer some general debugging suggestions.You wrote:>When I am trying to write to the interval timer at address 0xFF202000, the debugger won't proceed.Can you explain what you mean by "the debugger won't proceed"? Are you setting a breakpoint on config_interval_timer(), running to the breakpoint successfully, then single-stepping through its instructions? At which instruction does code execution stop proceeding as expected? Is a data abort exception occurring on the STR to address 0xFF202000 + 8 ?>When I try to look in the memory of 0xFF202000 in ARM DS, I also cannot see anything.In general, you should avoid using the Arm DS GUI Memory view to access volatile or read-sensitive peripheral registers, because the Memory view might read from a wider range of addresses, re-read that area multiple times, or cache values that it has read. Use the CLI instead, e.g:output /x *0xFF202008
Hope this helps
