Hello ,
I was just reading about scatter file and found this link below:
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0377c/Chdiehag.html
In chapter "Images with a complex memory map " the example shows how the memory is mapped for two object files.
DRAM 0x18000 0x8000 ; Start address for this exec region (0x18000),
; Maximum size of this exec region (0x8000)
program1.o (+RW, +ZI) ; Place all RW and ZI data from
; program1.o into this exec region
This lines specifies to the linker that Zero Initialized data shall be place into DRAM but in the execution view of the memory it appears in SRAM region (ZI Section #1)
Is the picture wrong or my understanding?
Thank you in advance !!
Hello raducara,
The link you provide seems to be incorrect, but I believe you referring to this Images with a complex memory map
I believe the Figure is correct: notice there are 2 Load Regions (LOAD_ROM_1 and LOAD_ROM_2). The execution section you mention DRAM is in LOAD_ROM_1 which is shown properly in the Execution view of the diagram at address 0x18000. LOAD_ROM_2 has the execution section SRAM which is whon properly in the the Execution view at address 0x08000.
Hope that helps,
-Duberly
Hello Duberly,
Thank you for the answer . My question was why ZI section 1 is placed in SRAM and ZI section 2 is placed in DRAM .
My understanding from the scatter file is that ZI sect 1 from prog1.o will be placed in DRAM and ZI sect 2 from prog2.o will be placed in SRAM.
I don't get it !!!!
Best
Radu.
Sent from Samsung Mobile
Hi Radu,
The graphic is wrong, RW#1/ZI#1 would both be in DRAM and RW#2/ZI#2 would be in SRAM.
No wonder you're confused!
Niall.
Thank you Niall !!!
I agree with Niall, the graph is not correct... I'll put forth a request for correction. Thanks. -Duberly
