freeRTOS demo DS-5 ERROR(CMD360) when trying to debug
I'm trying to program a Cyclone V SoC using DS-5 and I get the following errors:
Stopping running target Intel SoC FPGA - Cyclone V SoC (Dual Core) on connection
Connected to running target Intel SoC FPGA - Cyclone V SoC (Dual Core)
Execution stopped in SVC mode at S:0x3FF8D94C
S:0x3FF8D94C   B        {pc}-0xc ; 0x3ff8d940
cd "D:\UserData\z0045mwh\Documents\DS-5 Workspace"
Working directory "D:\UserData\z0045mwh\Documents\DS-5 Workspace"
source /v "C:\intelFPGA\18.1\embedded\ds-5\sw\debugger\configdb\Scripts\altera_target_check.py"
No SYSID registers could be found. Has a peripheral description file been supplied?
source /v "D:\UserData\z0045mwh\Documents\DS-5 Workspace\FreeRTOSv10.3.1\FreeRTOS\Demo\CORTEX_A9_Cyclone_V_SoC_DK\preloader.ds"
+stop
WARNING(CMD315): Target is not running
+wait 5s
+reset system
+wait 5s
+loadfile "$sdir/uboot-socfpga/spl/u-boot-spl" 0x0
Loaded section .text: S:0xFFFF0000 ~ S:0xFFFF671B (size 0x671C)
Loaded section .rodata: S:0xFFFF671C ~ S:0xFFFF82E4 (size 0x1BC9)
Loaded section .data: S:0xFFFF82E8 ~ S:0xFFFF91AF (size 0xEC8)
Entry point S:0xFFFF0000
Target has been reset
S:0x3FF8D94C   B        shift+1073273152 ; 0x3FF8D940
+set debug-from *$entrypoint     # Set start-at setting to address of $entrypoint
+start
Reloading program
Starting target with image D:\UserData\z0045mwh\Documents\DS-5 Workspace\FreeRTOSv10.3.1\FreeRTOS\Demo\CORTEX_A9_Cyclone_V_SoC_DK\uboot-socfpga\spl\u-boot-spl
Running from entry point
Execution stopped in SVC mode at S:0xFFFF0000
In start.S
Unable to read source file D:/SJ/nightly/14.0/200/w64/acds/embedded/examples/hardware/av_soc_devkit_ghrd/software/preloader/uboot-socfpga/arch/arm/cpu/armv7/start.S
S:0xFFFF0000   39,0   B        reset ; 0xFFFF0070
+delete
All user breakpoints deleted
+tbreak spl_boot_device
Breakpoint 2 at S:0xFFFF110C
    on file spl.c, line 70
    on file spl.c, line 80
+cont
+wait 60s
ERROR(CMD360):
# in D:\UserData\z0045mwh\Documents\DS-5 Workspace\FreeRTOSv10.3.1\FreeRTOS\Demo\CORTEX_A9_Cyclone_V_SoC_DK\preloader.ds:46 while executing: wait 60s
! Wait for stopped timed out
ERROR(CMD656): The script D:\UserData\z0045mwh\Documents\DS-5 Workspace\FreeRTOSv10.3.1\FreeRTOS\Demo\CORTEX_A9_Cyclone_V_SoC_DK\preloader.ds failed to complete due to an error during execution of the script
loadfile "D:\UserData\z0045mwh\Documents\DS-5 Workspace\FreeRTOSv10.3.1\FreeRTOS\Demo\CORTEX_A9_Cyclone_V_SoC_DK\Debug\RTOSDemo.elf"
ERROR(CMD16-TAD11-NAL33):
! Failed to load "RTOSDemo.elf"
! Failed to write 8 bytes to address N:0x0010C2D8
! Target is running, cannot access.
set debug-from main
start
ERROR(CMD350): Command not possible when running
wait
I'm also looking at the UART0 output and see this output:
data abort
    MAYBE you should read doc/README.arm-unaligned-accesses
pc : [<ffff018c>]          lr : [<ffff0074>]
sp : 3ff35630  ip : 00000010     fp : 00000001
r10: 3ffa2bb1  r9 : 3ffaceb8     r8 : 3ff35f60
r7 : 00000001  r6 : 3ffae32c     r5 : 400001a7  r4 : ffff8368
r3 : 00000000  r2 : c0000000     r1 : 00000048  r0 : 40000173
Flags: nZcv  IRQs off  FIQs off  Mode SVC_32
Resetting CPU ...
resetting ...
U-Boot SPL 2013.01.01 (Apr 08 2018 - 17:00:50)
BOARD : Altera SOCFPGA Cyclone V Board
CLOCK: EOSC1 clock 25000 KHz
CLOCK: EOSC2 clock 25000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 800 MHz
CLOCK: DDR clock 400 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 50000 KHz
CLOCK: QSPI clock 3125 KHz
RESET: WARM
INFO : Watchdog enabled
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 1024 MiB
ALTERA DWMMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2013.01.01 (Apr 08 2018 - 17:02:43)
CPU   : Altera SOCFPGA Platform
I2C:   ready
DRAM:  1 GiB
MMC:   ALTERA DWMMC: 0
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Skipped ethaddr assignment due to invalid EMAC address in EEPROM
Net:   mii0
Warning: failed to set MAC address
Hit any key to stop autoboot:  0
reading u-boot.scr
** Unable to read file u-boot.scr **
Optional boot script not found. Continuing to boot normally
reading zImage
** Unable to read file zImage **
reading socfpga.dtb
** Unable to read file socfpga.dtb **
Bad Linux ARM zImage magic!
SOCFPGA_CYCLONE5 #
Am I running into some problem because there is already a Linux kernel on the HPS already? Any help is greatly appreciated.
  • Hello, I believe you have the same issue as reported on the Intel forum below:
    https://community.intel.com/t5/Nios-II-Embedded-Design-Suite/DS-5-Baremetal-Failed-to-load-image/td-p/138277
    The solution mentioned there is to manually enable semihosting:
    set semihosting enabled true
  • Thank you.  That does seem to be  one of the issues I am having.  I believe I corrected it but now still have an issue with:
    In start.S
    which was in my error log but not the original poster's output.
  • The "Unable to read source file" message is displayed because the elf file that was loaded (D:\UserData\z0045mwh\Documents\DS-5 Workspace\FreeRTOSv10.3.1\FreeRTOS\Demo\CORTEX_A9_Cyclone_V_SoC_DK\uboot-socfpga\spl\u-boot-spl) includes symbols and knows the path/filenames of the original files used to compile the elf image.
    You can safely ignore this message.  It is not an error.  It is mentioning that it cannot find the source assembly/C file(s) associated with the current address of the breakpoint.  This is usually ok, in this case, since you want to stop the preloader at a safe place, then load the rest of the code.  You usually don't need to debug or step through the source in start.S.
    You can also download all the source code for the preloader, and provide path substitutions in the GUI to the location of the start.S (and the rest of the preloader source), but it is likely not needed.
    Here is more information on the path substitution used in both Arm DS and DS-5:
    https://developer.arm.com/documentation/dui0446/v/controlling-execution/configuring-the-debugger-path-substitution-rules
  • Thanks for the response.  It seems like I was mistaken that I solved the original problem then.  After adding the line "set semihosting enabled 1" in the preloader.ds I get the same errors with some additional ones now.
    Execution stopped in SVC mode at S:0xFFFF446C
    S:0xFFFF446C   B        {pc} ; 0xffff446c
    +stop
    +wait 5s
    +reset system
    +wait 5s
    Unable to read source file D:/SJ/nightly/14.0/200/w64/acds/embedded/examples/hardware/av_soc_devkit_ghrd/software/preloader/uboot-socfpga/common/spl/spl.c
    S:0xFFFF446C   56,0   B        hang+8 ; 0xFFFF446C
    +set semihosting enabled 1
    Semihosting server socket created at port 8001
    +start
    Reloading program
    In start.S
    +delete
    +cont
    +wait 60s
    ERROR(CMD360):
    # in D:\UserData\z0045mwh\Documents\DS-5 Workspace\FreeRTOSv10.3.1\FreeRTOS\Demo\CORTEX_A9_Cyclone_V_SoC_DK\preloader.ds:49 while executing: wait 60s
    ERROR(CMD16-TAD11-NAL22):
    ! Failed to write 8 bytes to address S:0x0011B754
    ! General error on memory or register access.
    ERROR(COR118-TAD1-NAL52):
    ! Unable to determine if stopped for semihosting
    ! Unable to read from register SPSR_UND
    ! Cannot attain state requested.
    Execution stopped in UND mode at S:0xFFFF0004
    ERROR(CMD256-TAD10-NAL52):
    ! Unable to display contents at location "S:0xFFFF0004"
    ! Failed to read 4 bytes from address S:0xFFFF0004
    set debug-from main
    start
    WARNING(CMD399-COR168):
    ! Failed to start the target
    ! No function named "main" could be found
    WARNING(CMD407): Trying the entry point instead
    ERROR(CMD399-CMD27-TAD1-NAL52):
    ! Failed to set a breakpoint
    wait
    ERROR(TAD1-NAL52):
    Target Message: Could not determine target state
    Any insight is greatly appreciated.
  • Is it possible to share this script? I don't know what exactly it does.
    Making an educated guess - it is initializing memory, but in your case, it takes more than 60 seconds (the CMD360 error), which tells me that something went wrong with that stage - then it tries to load the ELF file to this address, which therefore fails?
  • Here is the preloader.ds script
    # Copyright Altera 2013
    # All Rights Reserved
    # File: preloader.ds
    # stop processor if running
    stop
    wait 5s
    reset system
    wait 5s
    #set semihosting enabled
    # load the preloader (a.k.a the spl from our uboot dist)
    # set pc to entry point
    start
    # delete any breakpoints
    delete
    # set hw breakpoint in spl in function, spl_boot_device,
    # The function, spl_boot_device, is called right before the spl tries
    # to load.  We stop here so we don't have to change any spl.
    # tell target to continue executing spl
    cont
    # wait for breakpoint
    wait 60s
    I'm basically trying to follow these steps but on a different Cyclone V development board. I've updated the application code to control a GPIO that's connected to an LED on this board.
    https://www.freertos.org/RTOS_Altera_SoC_ARM_Cortex-A9.html#build_instructions
  • Also, you might be able to find answers directly from Intel, since Altera (now Intel) originally created the ds scripts above.  Their Embedded forum can be found here:
    https://community.intel.com/t5/Intel-SoC-FPGA-Embedded/bd-p/soc-fpga-embedded-development-suite
    There are also example designs included with SoCEDS. These containother scripts that might be useful.  These can be found here:
    https://fpgasoftware.intel.com/soceds/
  • any thoughts now that the script is included?
  • thanks for the reference.  I also posted a question over there as well.
  • Hi again,
    Sorry, I can't think of anything detailed to add - the script sets a breakpoint at "spl_boot_device" that is never hit, the script times out after 60 seconds.
    Perhaps try manually performing each step of the script, or set additional breakpoints - do you ever reach main()?
  • I'm stuck with the same very problem and cannot proceed. Were you able to solve it? I'm also getting the error:
    ERROR(CMD360):
    # in C:\Work\FreeRTOSv10.3.1\FreeRTOS\Demo\CORTEX_A9_Cyclone_V_SoC_DK\preloader.ds:45 while executing: wait 60s
    ERROR(CMD656): The script C:\Work\FreeRTOSv10.3.1\FreeRTOS\Demo\CORTEX_A9_Cyclone_V_SoC_DK\preloader.ds failed to complete due to an error during execution of the script
    loadfile "C:\Work\FreeRTOSv10.3.1\FreeRTOS\Demo\CORTEX_A9_Cyclone_V_SoC_DK\Debug\RTOSDemo.elf"
    ! Failed to write 8 bytes to address N:0x0015447C
    set debug-from main
    start
    Help would be very much appreciated.
    Kind regards,
    Filip in Sweden
  • Hi Filip,
    Sorry but I still don't have a solution to this.  It's taken a bit of a back seat lately while I work on more pressing issues.  Please let me know if you find a solution.
