Failed to load U-boot binary image
Hello!
I try to load and run U-boot binary image to RAM by DS-5. I use Jtag connection to my Arm-board
I defined Debug Configuration to run uboot.ds script, which should load and run u-boot image (for Linux).
The U-boot image is binary file having 1024 x 1024 = 1,048,576 bytes
This script fails on a specific line.
1. The original edition of this line (that I get from Arm-board provider) is:
 loadfile <path>/uboot.bin 0x0
The DS-5 Commands window, when running this line prints the following error:
+loadfile D:/Achilles/NfsFiles/uboot-socfpga/uboot.bin 0x0
ERROR(CMD16-COR107):
# in D:\Achilles\NfsFiles\uboot.ds:23 while executing: loadfile D:/Achilles/NfsFiles/uboot-socfpga/uboot.bin 0x0
! Failed to load "uboot.bin"
! Unable to detect image type of file "D:\Achilles\NfsFiles\uboot-socfpga\uboot.bin"
ERROR(CMD656): The script D:\Achilles\NfsFiles\uboot.ds failed to complete due to an error during execution of the script
2. When I replaced this original line by more matching (by my opinion):
restore <path>/uboot.bin binary 0x0
I get the following error
+restore D:/Achilles/NfsFiles/uboot-socfpga/uboot_rls.bin binary 0x0
Target Message: Memory access caused precise abort.
Debug Precise Abort Registers : DFSR = 0x00001808, DFAR = 0x00000000
ERROR(ITR205-TAD59-NAL18):
# in D:\Achilles\NfsFiles\uboot.ds:24 while executing: restore D:/Achilles/NfsFiles/uboot-socfpga/uboot.bin binary 0x0
! Unable to restore image
! Download of 1,048,576 bytes to address S:0x00000000 failed while writing block of 4,096 bytes to address S:0x00000000
! Bus error on memory operation.
  Please help,
    Yakov
  • Hi Yakov
    To load a plain binary image (as opposed to e.g. an ELF image), you are right that a "restore ... binary" command must be used.  See developer.arm.com/.../restore
    Regarding the download failure, are you sure you have RAM available at address 0x0 (rather than Flash), and it is writable?  Try opening a Memory view in the Debugger, and manually writing some test values to address 0x0.
    Please be aware that DS-5 is now quite old and has been superseded by "Arm Development Studio".   Are you able to update to Arm DS?  A free trial of the latest Arm DS Gold Edition is available from developer.arm.com/.../downloads
    Hope this helps
    Stephen
  • Hi Stephen,
    Thank you for the answer.
    Regarding your question "are you sure you have RAM available at address 0x0"
    Yes, I sure. I found ELF file and the line below works without error
    loadfile <path>/uboot.elf 0x0
    I can not upgrade DS-5 to the new version because I use Intel Development Kit for Altera FW design. DS-5 upgrade can cause to unpredictable behavior
      Best Regars,
         Yakov
