Pin output last state when programming
Hi all,
I'm using IAR 6.5 with MSP430, sometimes when I program the MCU the output pin goes on 'H' instead of 'L' and causing power failure (due to the analog function of that pin).
My assumption when I close the debugger while this pin in 'H' state it wont go down.
Is it possible to make sure the pin state while programming will stay on 'L'
Thanks,
Yariv
0
