I have input files called rin.pcm and sin.pcm. If i place them in the workspace and run my project. There is an error that the files cannot be found. Then I found that there is a specific path which the environment decides where the input files need to be specified. Is there a way to change the input fetch path to our liking.
Sorry I didnt mention the environment is DS-5
Please could you provide a screenshot of the error that you're seeing?
Thanks,
Joe
I believe set semihosting file-base ... is the command you are looking for. See the docs http://infocenter.arm.com/help/topic/com.arm.doc.dui0452t/CHDBCCFA.html
