I'm using DS-5 streamline to analyze some action on my board. after some testing i closed the program and next day when i opened it the eclipse stopped responding. it load the timeline view up till 99.9% then every thing freeeez. this problem happened before and was solved when i upgrade the DS-5. now my workspace is not working. if i try to import the zipfile version it is imported but never apear on the streamline side bar. can someone help me ??
Just for update when i try to use the streamline bar to import the zip file i receive the following error.
unexpected end of zlib input stream
Sounds like it may be trying to open a corrupted zip file?
What happens if you try to import the example Xaos capture?
As i said when i tried to load the same file with an older version it loaded successfully .
