I'm using STM32F4 Discovery and have the following problem. When I use the "Blinky" example, the L.A. works, but I can't make it work when creating my own project. The only difference I can see is the "Flash_OPT" group ... otherwise every setting seems to be the same. Did anybody have the same problem ?
luc
hi, relaying message from our tech dpt: behavior is linked to Keil/MDK features “Logic Analyzer”pure software, not to silicon or Discovery kit
Please refer to : http://www.keil.com/support/man/docs/uv4/uv4_db_dbg_logicanalyzer_setupex.htm to set it up the correct way
