I am seeing a failure to connect to the DSTREAM debugger from DS-5 version 5.20
Just upgraded the debugger firmware to 4.20 which came with this DS-5 version. When I double-click to connect I get this error. Can't find any history on this problem. Anyone seen this before?
Sorry you have experienced this - I had no issues after updating to DS-5 5.20.
Based on the error message, I would assume this is a license based error.
Open Help -> ARM License Manager. Does it report a valid license?
Do you also get other errors, for example compiler errors?
A boring answer may be to just reboot to make sure everything is properly installed.
If the issue persists, please raise an official support request.
3
Looks like I don't have any license problems. I went back and tried 5.19.1. No problems there. I'm going to use that moving forward until this issue with 5.20 is resolved.
