Hi Experts,
I went through the CMSIS RTX code for Cortex-M and bit curious on the features & configurations.
In that I could see osFeature_MainThread macro is defined for the requirement of main thread feature.
What is the practical use case (merits/de-merits) of using the osFeature_MainThread value as 0/1/.. ?
This requirement came from the 'mbed' project where the main function hides already all the setup. In retro-respective I think that the feature is not needed for deeply embedded systems where you typically setup the hardware and then you could start the osKernel.
Hi Reinhard,
So I could insert my hardware initialization routines there. Thanks for the reply.
Regards,
Techguyz
