Hi
I want to use arm_cfft_radix4_init_q15() and arm_cfft_radix4_q15() function from CMSIS 3.2 library . I am unable to find any good resources or any examples. I have looked in the documents provided by ARM i.e CMSIS-DSP: Complex FFT Functions but I didn't find it useful. What are the inputs given to these functions I am still not clear with it. I tried writing the codes but it didn't worked . Is their any example codes for FFT? I tried to implement the example code provided with the library but that didn't worked instead the memory of my uc overflowed and gave error.
this is how I am calling the function,
arm_cfft_radix4_init_q15(&arm_cfft_sR_q15_len256, 256, 0, 1); // For init
arm_cfft_radix4_q15(&arm_cfft_sR_q15_len256, az); // For transformation where,
arm_cfft_radix4_instance_q15 arm_cfft_sR_q15_len256 = {256, 0, 1, twiddleCoef_256, armBitRevIndexTable256, 4U, 4U};
and az[512] is an array where the data is stored. Just for testing
float32_t az[512] = {1.2 ,0.0
1.3, 0.0
1.2, 0.0};
my programs hangs and I am not able to print the o/p. I am using eclipse based IDE with ARM Cortex-M4 based microcontroller with 128kb flash, my uc is Little Endian, with s/w floating point unit. Please look into the matter.
Kind Regards
Amit Kumar
Hi, I'm in trouble with the CMSIS DSP library bitreversal function and solved it the workaround described here. Hope this helps.
Regards
Ibrahim
Hello Amit,
If you have gotten CMSIS by installing Keil, try checking your install folder equivalent to:
C:\Keil_5\ARM\CMSIS\DSP_Lib\Examples\arm_fft_bin_example\ARM
In that folder are several project files (.uvproj) for Cortex M0,M3,M4. It's a project which has a very simple example of how to use the cfft. Depending on how old of a version of CMSIS you're using, you'll either see cfft_radix4 (though probably f32), or the newer arm_cfft_f32.
If that doesn't answer your questions on how to use it, just post back here and we can figure it out.
Cheers,
Dan
