Hi All,
I am new to ARM compiler/linker tools. I am using RVDS221 for compilation.
I got this Errors related to linking the libraries. I checked in the errors and warnings guide, but dint understood
Please help me to resolve this.
V:\ASIC\users\c_thimma\sps\PPSS_VI\PPSS_VI_Interrupts\build\obj>armlink init_7.o heap.o stack.o PPSS_VI.o exceptions.o retarget.o PpssMain.o target_io.o gpio.o
gpio_int.o interrupt.o mcb.o timer.o test.o test_interrupt.o --info totals --entry 0x0000000 --map --list ..\image\ppss_vi_int.txt --scatter ..\scf\ppss_vi.scat --info sizes -o ..\image\ppss_vi_int.axf
Warning: L6310W: Unable to find ARM libraries.
Error: L6218E: Undefined symbol __main (referred from init_7.o).Error: L6218E: Undefined symbol _printf_str (referred from target_io.o).
Error: L6218E: Undefined symbol _scanf_string (referred from target_io.o).
Error: L6218E: Undefined symbol system (referred from target_io.o).
Error: L6218E: Undefined symbol __aeabi_uidivmod (referred from target_io.o).
Error: L6218E: Undefined symbol __aeabi_memclr4 (referred from target_io.o)Error: L6218E: Undefined symbol time (referred from target_io.o).
Error: L6218E: Undefined symbol strtoul (referred from target_io.o).
Error: L6218E: Undefined symbol __0scanf (referred from target_io.o).
Error: L6218E: Undefined symbol __0printf (referred from target_io.o).
Error: L6218E: Undefined symbol vsprintf (referred from target_io.o).
Error: L6218E: Undefined symbol __aeabi_d2uiz (referred from timer.o).
Error: L6218E: Undefined symbol __aeabi_dmul (referred from timer.o).
Error: L6218E: Undefined symbol __aeabi_ui2d (referred from timer.o).
Error: L6218E: Undefined symbol __aeabi_ddiv (referred from timer.o).
Not enough information to list the image map.
Finished: 1 information, 1 warning and 15 error messages.
Thanks,
ash
It looks to me like you are missing the path to your environment variable, so you may need to add it, as mentioned in the Infocenter docs:
This is most often caused by a missing or invalid value of the environment variable ARMCC41LIB or by incorrect arguments to --libpath. Set the the correct path with either the --libpath linker option or the ARMCCnnLIB environment variable. The default path for a Windows installation is: install_directory\RVCT\Data\...\lib Ensure this path does not include: \armlib \cpplib any trailing slashes (\) at the end. These are added by the linker automatically. Use --verbose or --info libraries to display where the linker is attempting to locate the libraries.See the following in the Linker Reference: --info=topic[,topic,...] --libpath=pathlist --verbose.
ARMCC41LIB
--libpath
ARMCCnnLIB
nn
install_directory
\armlib
\cpplib
--verbose
--info libraries
ARM Compiler toolchain Errors and Warnings Reference: List of the armlink error and warning messages
Hope this helps,
Joe
