I would like to crete assembly and binaries from c code, targeting arm v7 architecture.
I would like to use LLVM to do that. Is there any specific manual/documentation/website?
Thank you
Try this:
How To Cross-Compile Clang/LLVM using Clang/LLVM — LLVM 3.4 documentation
Thank you for the answer. Have you tried this? I am trying to do what it says but I get what is shown below. What is the problem? Thanks
-- The CXX compiler identification is Clang 3.5.0
-- Check for working CXX compiler using: Ninja
-- Check for working CXX compiler using: Ninja -- broken
CMake Error at /usr/share/cmake-2.8/Modules/CMakeTestCXXCompiler.cmake:54 (message):
The C++ compiler "/usr/bin/clang++" is not able to compile a simple test
program.
It fails with the following output:
Change Dir: /home/user/Desktop/llvm/llvm/new_build/CMakeFiles/CMakeTmp
Run Build Command:/usr/bin/ninja cmTryCompileExec1541562247
[1/2] Building CXX object
CMakeFiles/cmTryCompileExec1541562247.dir/testCXXCompiler.cxx.o
[2/2] Linking CXX executable cmTryCompileExec1541562247
FAILED: : && /usr/bin/clang++ -target armv7a-linux-gnueabihf
-mcpu=cortex-a9
-I/usr/arm-linux-gnueabihf/include/c++/4.7.2/arm-linux-gnueabihf/
-I/usr/arm-linux-gnueabihf/include/ -mfloat-abi=hard -ccc-gcc-name
arm-linux-gnueabihf-gcc
CMakeFiles/cmTryCompileExec1541562247.dir/testCXXCompiler.cxx.o -o
cmTryCompileExec1541562247 -rdynamic && :
/usr/bin/ld: unrecognised emulation mode: armelf_linux_eabi
Supported emulations: elf_x86_64 elf32_x86_64 elf_i386 i386linux elf_l1om
elf_k1om i386pep i386pe
clang: error: linker command failed with exit code 1 (use -v to see
invocation)
ninja: build stopped: subcommand failed.
CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
CMakeLists.txt:19 (project)
-- Configuring incomplete, errors occurred!
this answer is useful but is not exactly what I am looking for. This is about how to crosscompile clang/llvm using clang/llvm. So, you compile the compiler itself.
The more useful page would be http://clang.llvm.org/docs/CrossCompilation.html
Haris
