I use Keil uVision4 to build my project.
Here is my test C code:
void func(void)
//do something
printf("I hope to be recognized as RO-DATA!\n");
But assembler code is below. As u see, the string was put into RO-CODE section as inline data!
I realllllllllllllly want to know How to place a "short string" into [RO-DATA] section, but not in [RO-CODE(inc. data)] section?
Thanks!
func
0x00002c44: b510 .. PUSH {r4,lr}
0x00002c46: a013 .. ADR r0,{pc}+0x4e ; 0x2c94
0x00002c48: f000fc9a .... BL printf ; 0x3580
;; some other codes for RO-CODE section
$d
;; the string is here !
0x00002c94: 6f682049 I ** DCD 1869094985
0x00002c98: 74206570 pe t DCD 1948280176
0x00002c9c: 6562206f o be DCD 1700929647
0x00002ca0: 63657220 rec DCD 1667592736
0x00002ca4: 696e676f ogni DCD 1768843119
0x00002ca8: 2064657a zed DCD 543450490
0x00002cac: 52207361 as R DCD 1377858401
0x00002cb0: 41442d4f O-DA DCD 1094987087
0x00002cb4: 0a214154 TA!. DCD 169951572
0x00002cb8: 00000000 .... DCD 0
I don't know of a way to do that, but you do realize if if did do that it would be less efficient code as t would need to load a full address?
If you're wanting to share the strings between modules then I'd advise just having a message file which declares the strings as global const char msg_XYZ[]="x yy zzz"; No special pragmas or compiler options and it'll all go in the ro_data. Internationalization will also do it but normally via extra calls or an array, but then you're targeting more customers which is good.
As the previous reply points out, you have to declare your string separately to place it in the data section. In the following example, the string will be placed in the RODATA section.
const char string[]="string";
printf(string);
Hope this helps.
Chris
well, this method is not what i need, but really thank you very much!
i thought i must found another way because we are accustomed to use printf like this :
printf("put the str here directly");
thank u all the same
I'm glad you found the response useful. You are right that it is more usual to place the literal as one of the arguments to the printf function call and this is what most people do. As you have discovered, this will have the effect of placing the literal in the code section so it can easily be accessed at run-time without a linker fix-up.
I am slightly curious as to why you want to place the literal in the data section. Do you have a specific requirement which means that you need to do this?
