I’m now working on uV5.0 and find that uV5.0 responds too slow. Every time I click a button, like “OK”, uV5.0 will let me wait for a long time. And it takes a lot of time on building. For example, building a light weight project will costs me 3.5 mins. I think that is un-accepted.
I am wondering is there anyway to make uV5.0 runs more quickly. It makes me really suffered. Is it related to some limits of licence?
Any suggestion is appreciated.
Hello jefferey,
what kind of PC are you using? On my laptop Version 5 runs as fast as V4.x. Does your 4.x installation have the same problems?
Kind regards,
Christopher
I am running Windows 7 Enterprise 32-bit on my laptop.
Yes. I install back to uV4.7, and the same problem also bothers me.
Attached is a video showing how slowly the uV works on my laptop. Only finish compiling 7 files in nearly 2 mins.
Hello Jeffery,
I recommend to forward such requests to our Keil-Support address:
support.intl@keil.com
You're asked to login into our customer portal afterwards! Please follow the instructions you receive in reply!
Ralf
Ralf Kopsch
Senior Support Analyst
ARM Germany GmbH
HelloI had a similar issue. I also contacted support.intl@keil.com but i got no response from them. When i call keil compiler from DOS it works great but when i compile code inside uVision it is super slow.
I am surprised that you "got no response" from our Support-Team!
Please again send an email to:
and check for an automated reply explaining the login process to our customer portal www.silver.arm.com!
Inside this portal we do communicate with our customers, thank you!
Senior Applications Engineer
