IAR Linking issue at High optimization level
I am using IAR for development.
When i change the compiler option from None to High, it generates below linking error
Error[Lp011]: section placement failed
However if i disable static clustering option, it works even when optimization level is set as high...
Anyone knows whats the problem if i enable static clustering.
Regards,
Ashi Gupta
