Vitali,Can you tell me which version of ModelDebugger you are using and the file name of the ARMv8 target you are using?Chris
Hello,I try to run Model Debugger for ARMv8 target. It works fine if I choose to work with a single core.If change ARM.NUM_CORES to be, for example, 2, then a window for the cpu0 opens normally, but a window for cpu1 enters endless refresh loop (see the attached screenshot).The only way to get out of it is to "kill -9" the model debugger process. Can anyone please help to figure out what is going wrong? Thank you, Vitali
