n.18-1 1c __ vmull.u8 q12,d9 ,d17n.19-0 1c __ vmlal.u8 q12,d11,d19n.20-0 1c n0 vmlal.u8 q12,d12,d20n.21-0 1c n0 vmlal.u8 q12,d14,d22n.22-0 1c n0 vmlal.u8 q12,d2 ,d4 n.23-0 1c n0 vmlsl.u8 q12,d8 ,d16n.24-0 1c n0 vmlsl.u8 q12,d10,d18n.25-0 1c n0 vmlsl.u8 q12,d13,d21n.26-0 1c n0 vmlsl.u8 q12,d15,d23
n.35-0 2c n0 _____ vmul.s16 q12,q4 ,d0[0]n.39-0 2c n0 q12l:5 vmla.s16 q12,q5 ,d0[1]n.43-0 2c n0 q12l:5 vmla.s16 q12,q6 ,d0[2]n.47-0 2c n0 q12l:5 vmla.s16 q12,q7 ,d0[3]n.51-0 2c n0 q12l:5 vmla.s16 q12,q8 ,d1[0]n.55-0 2c n0 q12l:5 vmla.s16 q12,q9 ,d1[1]n.59-0 2c n0 q12l:5 vmla.s16 q12,q10,d1[2]n.63-0 2c n0 q12l:5 vmla.s16 q12,q11,d1[3]n.67-0 2c n0 q12l:5 vmla.s16 q12,q1 ,q2
If a multiply-accumulate follows a multiply or anothermultiply-accumulate, and depends on the result of that first instruction, thenif the dependency between both instructions are of the same type and size,the processor uses a special multiplier accumulator forwarding. This specialforwarding means the multiply instructions can issue back-to-back becausethe result of the first instruction in cycle 5 is forwarded to the accumulatorof the second instruction in cycle 4. If the size and type of the instructionsdo not match, then Dd or Qd is required in cycle 3. This applies tocombinations of the multiply-accumulate instructions VMLA, VMLS, VQDMLA,and VQDMLS, and the multiply instructions VMUL andVQDMUL.
n.9-0 1c n0 vmull.s16 q13,d9 ,d0[0]n.10-0 1c n0 vmlal.s16 q13,d11,d0[1]n.11-0 1c n0 vmlal.s16 q13,d13,d0[2]n.12-0 1c n0 vmlal.s16 q13,d15,d0[3]n.13-0 1c n0 vmlal.s16 q13,d17,d1[0]n.14-0 1c n0 vmlal.s16 q13,d19,d1[1]n.15-0 1c n0 vmlal.s16 q13,d21,d1[2]n.16-0 1c n0 vmlal.s16 q13,d23,d1[3]
If you think about it, this behavior is what you would expect. The NEON unit on Cortex-A8 and Cortex-A9 can do 4x16-bit multiplications in one cycle. Doing an 8x16-bit multiplication is like doing two 4x16-bit ones back to back, and takes two cycles. Because it's like alternating between two different multiplications it can't forward the result because it'd have to forward two things where there's probably only one internal accumulator.
vmul.s16 q12,q4 ,d0[0]vmla.s16 q12,q5 ,d0[1]vmla.s16 q12,q6 ,d0[2]vmla.s16 q12,q7 ,d0[3]vmla.s16 q12,q8 ,d1[0]vmla.s16 q12,q9 ,d1[1]vmla.s16 q12,q10,d1[2]vmla.s16 q12,q11,d1[3]vmla.s16 q12,q1 ,q2
vmul.s16 d24,d8 ,d0[0]vmul.s16 d25,d9 ,d0[0]vmla.s16 q24,d10,d0[1]vmla.s16 d25,d11,d0[1]vmla.s16 d24,d12,d0[2]vmla.s16 d25,d13,d0[2]vmla.s16 d24,d14,d0[3]vmla.s16 d25,d15,d0[3]vmla.s16 d24,d16,d1[0]vmla.s16 d25,d17,d1[0]vmla.s16 d24,d18,d1[1]vmla.s16 d25,d19,d1[1]vmla.s16 d24,d20,d1[2]vmla.s16 d25,d21,d1[2]vmla.s16 d24,d22,d1[3]vmla.s16 d25,d23,d1[3]vmla.s16 d24,d2 ,d4vmla.s16 d25,d3 ,d5
vmul.s16 d24,d8 ,d0[0]vmla.s16 q24,d10,d0[1]vmla.s16 d24,d12,d0[2]vmla.s16 d24,d14,d0[3]vmla.s16 d24,d16,d1[0]vmla.s16 d24,d18,d1[1]vmla.s16 d24,d20,d1[2]vmla.s16 d24,d22,d1[3]vmla.s16 d24,d2 ,d4vmul.s16 d25,d9 ,d0[0]vmla.s16 d25,d11,d0[1]vmla.s16 d25,d13,d0[2]vmla.s16 d25,d15,d0[3]vmla.s16 d25,d17,d1[0]vmla.s16 d25,d19,d1[1]vmla.s16 d25,d21,d1[2]vmla.s16 d25,d23,d1[3]vmla.s16 d25,d3 ,d5
