Hi Chandrakala,Some of the intrinsics are not defined and the compiler can figure out when to use them by analysis of the code. In order to use SMLAD, use something like:z + ((short)(x>>16)*(short)(y>>16)) + ((short)x*(short)y)After you compile, check the generated code to make sure that the intrinsic is being accessed.
Hi,Iam working on ARM11 RVDS3.0. Iam trying to use SIMD intrinsics which are defined for ARM11. I tried to used __smlad intrinsic, but it is giving linking error. Following is the usage. int a, b, c; c=__smlad(a,b,c);For this the error i got is Error : armlink : L6218: Undefined symbol __smlad (referred from residu.o).Am i missing any thing here. do i need to include any header file. if YES, which file i should include.Thanks in advance,Chandrakala
