how to copy files to iMX8MP virtual hardware file system?
1. How to copy files to iMX8MP virtual hardware? I have followed below steps and didnt work for me. Is there any other way to copy files to/from virtual hardware to host pc?
         1. Download the source provided by AVH for iMX8MP 2.2.0/2.2.1 version.
          2. Extracted the zip contents and then used mount commands to mount nand file system. Then added the files to /home/root directory of nand and then unmounted and created .zip file from this modified nand file.
          3. Loaded this .zip image while creating the device. This gives error " Unable to find Linux binary....." .
2. How to setup SSH connection from Host PC to Virtual hardware?
Regards,
Sunitha
  • Hi Sunitha, the i.MX8M Plus device runs Linux so you can use standard Linux commands like scp or wget to copy files to your i.MX8M Plus device.
    If you are trying to copy files from your local machine to the i.MX8M Plus device you'll want to make sure that you have established an OpenVPN connection first.
    If you have any other questions on this, please feel free to contact avhsupport@corellium.com
  • If you want to ssh directly to your device without using OpenVPN,  then you can do so using the directions in the Connect tab to the left of your console window.  It will give you the exact command that you can paste into your terminal to ssh directly into the i.MX8M Plus device.  Note that in order to use ssh, you first need to share your public key.  Instructions on this process, including adding your ssh key can be found here: https://support.avh.corellium.com/features/connect/quick-connect
