FVP Model: FVP_Base_RevC-2xAEMvAversion: Fast Models [11.23.9 (Sep 12 2023)]
RUN Parameters:
FVP_Base_RevC-2xAEMvA \ -C pctl.startup=0.0.0.0 \ -C bp.secure_memory=0 \ -C cluster0.NUM_CORES=4 \ -C cluster1.NUM_CORES=4 \ -C cache_state_modelled=0 \ -C cluster0.cpu0.RVBAR=0x04020000 \ -C cluster0.cpu1.RVBAR=0x04020000 \ -C cluster0.cpu2.RVBAR=0x04020000 \ -C cluster0.cpu3.RVBAR=0x04020000 \ -C bp.hostbridge.userNetPorts="8023=22" \ -C bp.hostbridge.userNetworking=true \ -C bp.pl011_uart0.untimed_fifos=1 \ -C bp.pl011_uart0.unbuffered_output=1 \ -C bp.pl011_uart1.untimed_fifos=1 \ -C bp.pl011_uart1.unbuffered_output=1 \ -C bp.pl011_uart0.out_file=./uart0.log \ -C bp.pl011_uart1.out_file=./uart1.log \ -C bp.dram_size=8 \ -C bp.smsc_91c111.enabled=true \ -C pci.pcivirtioblockdevice1.image_path=$IMGS/sd.img \ --data cluster0.cpu0=$IMGS/bl31.bin@0x04020000 \ --data cluster0.cpu0=$IMGS/Image@0x80080000 \ --data cluster0.cpu0=$IMGS/fvp-base-revc.dtb@0x90000000 \ --data cluster0.cpu0=$IMGS/Initrd@0xa0000000 -p $@
FVP_Base_RevC-2xAEMvA: command line option --print-port-number ignored because no --cadi-server or --iris-server option specified terminal_0: Listening for serial connection on port 5000 terminal_1: Listening for serial connection on port 5001 terminal_2: Listening for serial connection on port 5002 terminal_3: Listening for serial connection on port 5003 Warning: FVP_Base_RevC_2xAEMvA: ErrorBlock: Simulator only error message was sent by 0:2.0 but not acknowledged by Root Complex In file: (unknown):0 In process: FVP_Base_RevC_2xAEMvA.thread_p_27 @ 11943389820 ns Warning: FVP_Base_RevC_2xAEMvA: Virtio device failed to read memory at 0x0000000880839002 In file: (unknown):0 In process: FVP_Base_RevC_2xAEMvA.thread_p_27 @ 11943389820 ns Warning: FVP_Base_RevC_2xAEMvA: ErrorBlock: Simulator only error message was sent by 0:2.0 but not acknowledged by Root Complex In file: (unknown):0 In process: FVP_Base_RevC_2xAEMvA.thread_p_27 @ 11943389820 ns Warning: FVP_Base_RevC_2xAEMvA: Virtio device failed to read memory at 0x0000000880839004 In file: (unknown):0 In process: FVP_Base_RevC_2xAEMvA.thread_p_27 @ 11943389820 ns It seems that some issue is met during device initializing, and linux kernel is blocked by smmu configuration.
Is there any suggestion?
