Hi, I am using Foudation in FVP. I get files from linaro with bl31.bin , fip.bin , Image e ramdisk.img . Workinh without problem.
I compile trusted firmware and i have tested with the news bl1.bin e fib.bin .
The first tests the boot dont read kernel. I change parameters to compile trusted firmware and now read the kernel but
have a kernel panic with a message unable to mount root fs.
I change only bl1.bin e fip.bin.
I run
/home/serfau/dir-arm/Foundation_Platformpkg/models/Linux64_GCC-9.3/Foundation_Platform \--cores=4 \--no-secure-memory \--visualization \--use-real-time \--gicv3 \--data=/home/serfau/tfa/arm-trusted-firmware/build/fvp/release/bl1.bin@0x0 \--data=/home/serfau/tfa/arm-trusted-firmware/build/fvp/release/fip.bin@0x8000000 \--data=Image@0x80080000 \--data=foundation-v8-gicv3.dtb@0x82000000 \--data=ramdisk.img@0x84000000 \--arm-v8.0
i compile trusted firmware with
CROSS_COMPILE=/home/serfau/tfa/arm-gnu-toolchain-13.2.Rel1-x86_64-aarch64-none-elf/bin/aarch64-none-elf- \make PLAT=fvp DEBUG=0 \ARM_LINUX_KERNEL_AS_BL33=1 \PRELOADED_BL33_BASE=0x80080000 \ARM_PRELOADED_DTB_BASE=0x82000000 \ARM_ROTPK_LOCATION=regs \ARM_TSP_RAM_LOCATION=tdram \FVP_USE_GIC_DRIVER=FVP_GICV3 \all fip
Anyone help-me ?
