I want to try Virtual Interface using Python script for testing VIO/IO automation on Keil Studio Cloud.
https://arm-software.github.io/AVH/main/simulation/html/index.html#Virtual_Interfaces
Sample code is going to be generated with following repo:
https://github.com/Arm-Examples/AWS_MQTT_MutualAuth_Demo
My understanding, KSC doesn't generate FVP, so you can't execute the FVP exec application with the commandline like following:
VHT_MPS3_Corstone_SSE-300 -f Board/AVH_MPS3_Corstone-300/fvp_config.txt -a <image> -V path.py
Unfortunately, I can't try on other host such as Amazon EC2 instances because I don't have Arm Compiler license.
