I am following the instructions here: Tool-Solutions/mlops-cloud at master · ARM-software/Tool-Solutions (github.com)
But I am not able to connect to the instance. I tried both powershell and MobaXTerm and in both cases it fails.
Here is what I tried with powershell:
ssh -i ArmVirtualHardwareKeyPair_pem.pem ubuntu@44.203.220.84 -v
And this is the output:
OpenSSH_for_Windows_8.1p1, LibreSSL 3.0.2debug1: Connecting to 44.203.220.84 [44.203.220.84] port 22.debug1: Connection established.debug1: identity file ArmVirtualHardwareKeyPair_pem.pem type -1debug1: identity file ArmVirtualHardwareKeyPair_pem.pem-cert type -1debug1: Local version string SSH-2.0-OpenSSH_for_Windows_8.1debug1: Remote protocol version 2.0, remote software version OpenSSH_8.2p1 Ubuntu-4ubuntu0.4debug1: match: OpenSSH_8.2p1 Ubuntu-4ubuntu0.4 pat OpenSSH* compat 0x04000000debug1: Authenticating to 44.203.220.84:22 as 'ubuntu'debug1: SSH2_MSG_KEXINIT sentdebug1: SSH2_MSG_KEXINIT receiveddebug1: kex: algorithm: curve25519-sha256debug1: kex: host key algorithm: ecdsa-sha2-nistp256debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: nonedebug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: nonedebug1: expecting SSH2_MSG_KEX_ECDH_REPLYdebug1: Server host key: ecdsa-sha2-nistp256 SHA256:/QQuOSjmopkxTqei5Z4BRDufc79dyyCU837KSkayLHQdebug1: Host '44.203.220.84' is known and matches the ECDSA host key.debug1: Found key in C:\\Users\\Eyal/.ssh/known_hosts:1debug1: rekey out after 134217728 blocksdebug1: SSH2_MSG_NEWKEYS sentdebug1: expecting SSH2_MSG_NEWKEYSdebug1: SSH2_MSG_NEWKEYS receiveddebug1: rekey in after 134217728 blocksdebug1: pubkey_prepare: ssh_get_authentication_socket: No such file or directorydebug1: Will attempt key: ArmVirtualHardwareKeyPair_pem.pem explicitdebug1: SSH2_MSG_EXT_INFO receiveddebug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,sk-ssh-ed25519@openssh.com,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,sk-ecdsa-sha2-nistp256@openssh.com>debug1: SSH2_MSG_SERVICE_ACCEPT receiveddebug1: Authentications that can continue: publickeydebug1: Next authentication method: publickeydebug1: Trying private key: ArmVirtualHardwareKeyPair_pem.pemdebug1: Authentications that can continue: publickeydebug1: No more authentication methods to try.ubuntu@44.203.220.84: Permission denied (publickey).
I also tried it this way:
ssh -i "ArmVirtualHardwareKeyPair_pem.pem" ubuntu@ec2-44-203-220-84.compute-1.amazonaws.com -v
OpenSSH_for_Windows_8.1p1, LibreSSL 3.0.2debug1: Connecting to ec2-44-203-220-84.compute-1.amazonaws.com [44.203.220.84] port 22.debug1: Connection established.debug1: identity file ArmVirtualHardwareKeyPair_pem.pem type -1debug1: identity file ArmVirtualHardwareKeyPair_pem.pem-cert type -1debug1: Local version string SSH-2.0-OpenSSH_for_Windows_8.1debug1: Remote protocol version 2.0, remote software version OpenSSH_8.2p1 Ubuntu-4ubuntu0.4debug1: match: OpenSSH_8.2p1 Ubuntu-4ubuntu0.4 pat OpenSSH* compat 0x04000000debug1: Authenticating to ec2-44-203-220-84.compute-1.amazonaws.com:22 as 'ubuntu'debug1: SSH2_MSG_KEXINIT sentdebug1: SSH2_MSG_KEXINIT receiveddebug1: kex: algorithm: curve25519-sha256debug1: kex: host key algorithm: ecdsa-sha2-nistp256debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: nonedebug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: nonedebug1: expecting SSH2_MSG_KEX_ECDH_REPLYdebug1: Server host key: ecdsa-sha2-nistp256 SHA256:/QQuOSjmopkxTqei5Z4BRDufc79dyyCU837KSkayLHQdebug1: Host 'ec2-44-203-220-84.compute-1.amazonaws.com' is known and matches the ECDSA host key.debug1: Found key in C:\\Users\\Eyal/.ssh/known_hosts:2debug1: rekey out after 134217728 blocksdebug1: SSH2_MSG_NEWKEYS sentdebug1: expecting SSH2_MSG_NEWKEYSdebug1: SSH2_MSG_NEWKEYS receiveddebug1: rekey in after 134217728 blocksdebug1: pubkey_prepare: ssh_get_authentication_socket: No such file or directorydebug1: Will attempt key: ArmVirtualHardwareKeyPair_pem.pem explicitdebug1: SSH2_MSG_EXT_INFO receiveddebug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,sk-ssh-ed25519@openssh.com,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,sk-ecdsa-sha2-nistp256@openssh.com>debug1: SSH2_MSG_SERVICE_ACCEPT receiveddebug1: Authentications that can continue: publickeydebug1: Next authentication method: publickeydebug1: Trying private key: ArmVirtualHardwareKeyPair_pem.pemdebug1: Authentications that can continue: publickeydebug1: No more authentication methods to try.ubuntu@ec2-44-203-220-84.compute-1.amazonaws.com: Permission denied (publickey).
In MobaXTerm I get:
No supported authentication methods available (server sent: publickey)
