Processor sometimes ignoring WFI instruction
Hello everyone,
I have a problem with WFI instruction and deep sleep mode.
Normally everything work correct, but sometimes processor ignore instruction WFI and continue work.
I use ARM Cortex-M0+ (exactly STM32L051), and below is my sleep procedure:
	__ASM volatile ("cpsid i" : : : "memory");
	// if WKUP pins are already high, the WUF bit will be set
	PWR->CSR |= PWR_CSR_EWUP2;
	PWR->CR |=	PWR_CR_CWUF	|				// clear the WUF flag after 2 clock cycles
		    	PWR_CR_CSBF	|				// clear StandBy flag
		    	PWR_CR_ULP;					// V_{REFINT} is off in low-power mode
	PWR->CR |=	PWR_CR_LPSDSR |				//
		    	PWR_CR_PDDS;				// Enter Standby mode when the CPU enters deepsleep
	SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;		// low-power mode = stop mode
	__WFI();								// enter low-power mode
	while(1)
		uprintf("Interrupt loop");
I haven't found information on the conditions that must be met before use WFI in deep sleep mode.
  • Did you check if an interrupt is pending?
  • In the older version of program yes, I check it in the NVIC_ICPR registry, and sometimes something is there.
    But I had a problem with disabling reaction NVIC at any interrpupts.
    SYSCFG->EXTICR[0] = 0;            // disable external interrupt prom pin
    NVIC_DisableIRQ( EXTI2_3_IRQn );   // disable interrupt from pin
    while(NVIC->ICPR[0]&(1<<EXTI2_3_IRQn))
       Send_USART("Interrupt!");
       NVIC->ICPR[0] = 0xFFFFFFFF;  // clear all interrupt pending
    In this code loop never ending.
  • Not sure, but you might have to clear the "active" bit as well.
    And, you may need to clear the EXTI pending bit also.
  • Now I have:
    	EXTI->IMR = 0;						// clear all interrupt mask
    	NVIC_DisableIRQ( EXTI2_3_IRQn );	// disable interrupt from INT pin
    	EXTI->PR |= EXTI_PR_PIF2; 			// clear interrupt pending flag
    	__disable_irq();
    	if(NVIC->ICPR[0])
    		Send_USART("Interrupt!->");
    		USART_unr32(NVIC->ICPR[0]);
    		USART_send( 0x0D );
    		USART_send( 0x0A );
    		NVIC->ICPR[0] = 64;
    		USART_send( ' ' );
    		USART_send( 0x0D );
    		USART_send( 0x0A );
    Now it's working fine, registry NVIC->ICPR[0] newer have penging bits.
    I will be watching the operation of the program, but I think that this is the solution to the problem.
