MPU is not triggering MemManage fault. I want to protect a memory region of 64 bytes starting from 0x20000000. I've configured the MPU registers accordingly, but when I write in a protected memory location, MPU does not trigger fault.
Here's a code that demonstrate the problem,
#define MPU_CTRL (*((volatile unsigned long*) 0xE000ED94))#define MPU_RNR (*((volatile unsigned long*) 0xE000ED98))#define MPU_RBAR (*((volatile unsigned long*) 0xE000ED9C))#define MPU_RASR (*((volatile unsigned long*) 0xE000EDA0))
#define SCB_SHCSR (*((volatile unsigned long*) 0xE000ED24)) //System handler control and state register void Registers_Init(void){ //MPU Configuring
MPU_RNR = 0x00000000; // region in 0. MPU_RBAR = 0x20000000; // base address is 0x20000000. MPU_RASR = 0x1608FF0B; // 64 bytes, ro/ro, b=s=c=0 SCB_SHCSR |= 0x00010000; // enable MemManage Fault
MPU_CTRL = 0x00000005; // enable memory protection unit,guaranteeing default priviliged access}
void MemManage_Handler(void) {
__asm( "MOV R4, 0x77777777\n\t" "MOV R5, 0x77777777\n\t" );}
void HardFault_Handler(void){ __asm( "MOV R6, 0x77777777\n\t" "MOV R7, 0x77777777\n\t" );}
int main(void){ Registers_Init();
while(1) { __asm( "LDR R0, =0x20000000\n\t" "MOV R1, 0x77777777\n\t" "STR R1, [R5,#0]" ); } return (1);}
void SystemInit(void){}
So, in main function I am writing in a memory location protected by mpu. But instead of generating MemManage fault or even HardFault, it writes successfully.
Why is that?
Hi Muzahir,
I have moved your question to the processors community as they may be best placed to answer your question.
In the main() "LDR R0, =0x20000000\n\t" "MOV R1, 0x77777777\n\t" "STR R1, [R5,#0]"
What is in R5?
It is maybe no good idea to move rather old questions into another forum where it pops up as a new question.
Hi 42Bastian Schick,
The reason for moving this question was due to it remaining unanswered when placed within the 'Community Help' discussions. From reading the question I thought it would be best placed within the 'Processors' community to see if an answer could be given. For older questions I am contacting individuals to ask if their question still requires an answer before taking further action.
Writing RBAR misses the valid-bit, which might another reason (besides the typo of R5 instead of R0, see Joseph Yiu's answer).
