Help Choosing a processor
I have been given the task of selecting a suitable processor for a project in which we will have a dedicated processor.
The project will involve configuring HW and inverting matrices in C.  We will use the Cholesky algorithm in double precision.  We don't plan to use any OS but run the app bare metal.  We have to handle DDR memory transfer and interrupts.  The maximum size of the matrix will be around 1.2MB.
Some noob questions I have are:
Will using a DP FPU help as we use our algorithms in DP?  I know it may sound obvious but I know obvious things usually are not what they seem.  How much benefit will that give?
Are there any processors which support a large enough L2 cache to fit the data?
Are the different ISAs of any benefit here?  I see that the ARMv8-M has "Floating point extension architecture v5 "  Is this something that should be considered?
Performance is key here, we must invert the matrices every 250ms and we hope it doesn't take more than 30ms to do the inversion.
Any other pointers on what I should look for when selecting a processor would be appreciated.  I was thinking a processor speed of at least 700MHz would be needed.
0
