Hi everyone,
Wherever I go on internet, the thing I read is that when SMC instruction is executed an exception is generated, it takes you to the highest exception level (EL3) where secure monitor is running.
In ARM v8 vector table, given on ARMv8-A architecture reference manual page 1800, there are four types of exceptions:
As there is no exception with name SMC, I want to ask under which exception type does SMC fall? If I have a baremetal program running on Cortex-A72, what do I need to do if want to write a SMC handler?
Any answers will be highly appreciated,
This group focuses on Trustzone for ARMv8-M, ARMv8-A Trustzone questions will get a quicker answer on the "Processors" forum.
In this case SMC is a type of Synchronous exception so will cause that handler to run. The ESR_ELx register lets the handler work out what type of exception it was, SMC, SVC, trapped access, synchronous data abort...
