i just want to know which processors are very advanced processors in cortex-A,R and M series.
Is it OK for an answer that Cortex-A72 is it in the 64bit Cortex-A, Cortex-A17 (or in a sense, Cortex-A15) is it in the 32bit Cortex-A, Cortex-R7 is it in Cortex-R and Cortex-M7 is it in Cortex-M?
Best regards,
Yasuhiko Koumoto.
Hi, I think it depends on what Karthigowri considers advanced... and if it is for available products.
Today, you cannot buy an ARM Cortex-A72. That's a processor for the future.
Today, the ARM Cortex-A53 and ARM Cortex-A57 are the big guys. Both of them support both 32-bit (=AARCH32 ISA) and 64-bit (=AARCH64 ISA) instruction sets and the big.LITTLE configuration. However, the silicon vendor can choose to only implement one of them...
On the ARM Cortex-M, if you want the smallest microcontroller, then you would look for an ARM Cortex-M0+ whereas the ARM Cortex-M7-based microcontrollers deliver more performance. For FPGA implementation, the less known ARM Cortex-M1 core should be considered.
The latest product announced was the ARM Cortex-R7. I can advise you to read Chris Turner and Neil Werdmuller content on the matter.
Karthigowri,
What kind of requirements do you have? Are you only looking at "horse-power" or are you interested in other points like pipeline, instruction set, virtualization...
and welcome to the ARM Connected Community!
Alban Rampon.
Just to be sure about your question... What you mean by advanced ?
Technologically advanced or the most used (software developement) ?
