PMU (Performance monitor Unit)
How can I use PMU(Performance Monitor Unit) in ARM11 to calculate execution clock cycles of an assembly code.
I am using raspberry pi Model B. I am programming it in assembly language (running assembly program as OS). And want to calculate number of clock cycles it takes to execute my code.
  • Hello,
    according to the ARM1176JZZFS TRM. the following procedures would be taken the number of execution cycles of a target codes.
      /* Enable PMU */
      mov r0,#1
      MCR p15, 0, r0, c15, c12, 0 ; Write Performance Monitor Control Register
      /* Reset Cycle Counter */
      mov r0,#5
      /* Meaure */
      MRC p15, 0, r0, c15, c12, 1 @ Read Cycle Counter Register
      <your code>
      MRC p15, 0, r1, c15, c12, 1 @ Read Cycle Counter Register
      sub r0.r1.r0                @ Cycle Count of <your code
    Best regards,
    Yasuhiko Koumoto.
  • Hi,
    Is there any way I can read register values after execution of an assembly program?
    May be save in a file(text or csv etc. on sdcard) or any other easy method?
  • Hi,
    if you use Raspberry Pi, I think there would be the self C compiler implemented. So, you can use the fprintf function to store the PMU results. I'm not sure this can be possible because I don't have Raspberry Pi.
    Best regards,
    Yasuhiko Koumoto.
