Hello....!!!
Can anyone tell the minimum and maximum frequency or bandwidth on which AMBA AHB, APB, AXI and CHI and ACE can work successfully?
Hi ajoo,
I don't think there can possibly be an absolute answer to this question as the maximum frequency for any of these protocols will depend significantly on the system complexity, the cell library being used, and also a bit down to how much effort is put into the synthesis.
And as far as the minimum is concerned, they can run as slow as you want to clock them, all the way down to stopping the clock (if the system function allows).
JD
