CortexA8 L2 data loss
Hi at all!
I'm working with TI DM3730 (CortexA8 inside) and an external mobile DDR-SDRAM.
The startup initialize MMU, L1 Cache and L2 Cache and Flow Prediction.
Tests with about 256MiB of data show some data loss when L2 Cache is enabled.
If L2 is disabled and only L1 I and D Cache is enabled, the data tests work properly.
Here is my MMU-Setting:
Device-Registers: AP = 3, mode = 2, TEX = 0, C = 0, B = 0
internal RAM: AP = 3, TEX  = 0, C = 1, B = 0
external RAM: AP = 3, TEX = 0, C = 1, B = 0
all areas are mapped to domain 0 and all domains are set to client mode.
If the MMU-Settings for external RAM are set to TEX = 0, C = 0 and B = 0 (disable caching for external RAM), there is also no data loss and all work fine.
Anyone an idea?
Here is the complete code of initialization:
  *   disable 'Instruction Cache' , 'Flow Prediction'
  *   disable 'Data Cache' , 'MMU'
  *   enable  'Alignment check'
  mrc     p15, 0, r0, c1, c0, 1       // read auxiliary control register
  bic     r0, r0, #(0x1 << 1)         // disable L2-Cache
  mcr     p15, 0, r0, c1, c0, 1       // write back
  mrc     p15, 0, r0, c1, c0, 0       // read control register
  bic     r0, r0, #(0x1 << 0)         // disable MMU
  orr     r0, r0, #(0x1 << 1)         // enable Strict alignment fault checking
  bic     r0, r0, #(0x1 << 2)         // disable D-Cache
  bic     r0, r0, #(0x1 << 11)        // disable Flow prediction
  bic     r0, r0, #(0x1 << 12)        // disable I-Cache
  bic     r0, r0, #(0x1 << 13)        // Use Normal exception vector
  mcr     p15, 0, r0, c1, c0, 0       // write back
  *   set 'Vectore Base Address'
  ldr     r0, =dm3730_initVector
  mcr     p15, 0, r0, c12, c0, 0
  *   Invalidate 'Translation Table Base' (TLB)
  *   Invalidate 'Instruction Cache' und
  *               lösche 'branch target cache'
  mov     r0, #0
  mcr     p15, 0, r0, c8, c7, 0       // Invalidate Inst-TLB und Data-TLB
  mcr     p15, 0, r0, c7, c5, 0       // Invalidate all instruction caches and flushes branch target cache
  *   Cache Invalidation code ->
  *    github.com/.../startup.s
  mrc     p15, 1, r0, c0, c0, 1                   // Read CLIDR
  ands    r3, r0, #0x07000000                     // Extract coherency level
  mov     r3, r3, lsr #23                         // Total cache levels << 1
  beq     processor_FirstBootEntry_cacheExit      // If 0, no need to clean
  mov     r8, #0                                  // R8 holds current cache level << 1
processor_FirstBootEntry_cacheLoop1:
  add     r2, r8, r8, lsr #1                      // R2 holds cache "Set" position
  mov     r1, r0, lsr r2                          // Bottom 3 bits are the Cache-type for this level
  and     r1, r1, #7                              // Isolate those lower 3 bits
  cmp     r1, #2
  blt     processor_FirstBootEntry_cacheSkip      // No cache or only instruction cache at this level
  mcr     p15, 2, r8, c0, c0, 0                   // Write the Cache Size selection register
  ISB                                             // ISB to sync the change to the CacheSizeID reg
  mrc     p15, 1, r1, c0, c0, 0                   // Reads current Cache Size ID register
  and     r2, r1, #7                              // Extract the line length field
  add     r2, r2, #4                              // Add 4 for the line length offset (log2 16 bytes)
  movw    r4, #0x3ff
  ands    r4, r4, r1, LSR #3                      // R4 is the max number on the way size (right aligned)
  clz     r5, r4                                  // R5 is the bit position of the way size increment
  movw    r6, #0x7FFF
  ands    r6, r6, r1, LSR #13                     // R6 is the max number of the index size (right aligned)
processor_FirstBootEntry_cacheLoop2:
  mov     r7, r4                                  // R7 working copy of the max way size (right aligned)
processor_FirstBootEntry_cacheLoop3:
  orr     r1, r8, r7, lsl r5                      // Factor in the Way number and cache number into R1
  orr     r1, r1, r6, lsl r2                      // Factor in the Set number
  mcr     p15, 0, r1, c7, c6, 2                   // Invalidate by Set/Way
  subs    r7, r7, #1                              // Decrement the Way number
  bge     processor_FirstBootEntry_cacheLoop3
  subs    r6, r6, #1                              // Decrement the Set number
  bge     processor_FirstBootEntry_cacheLoop2
processor_FirstBootEntry_cacheSkip:
  add     r8, r8, #2                              // increment the cache number
  cmp     r3, r8
  bgt     processor_FirstBootEntry_cacheLoop1
processor_FirstBootEntry_cacheExit:
  DSB
   *   MMU Settings
   // Hier Code kopieren vom Cache-Handling
   /* invalidate TLB */
   mov     r0, #0
   mcr     p15, 0, r0, c8, c7, 0       // set TLB for instruction and data invalid
   /* TLB Addr setzen */
   mov     r0, #0
   mcr     p15, 0, r0, c2, c0, 2       // set Table-Base-Control register to 0
   ldr     r0, =mmuL1PageTable         // load addr of MMU-L1-PageTable
   mcr     p15, 0, r0, c2, c0, 0       // set addr of MMU-L1-PageTable
    *   Setup domain control register -
    *   Enable all domains to client mode
  movw    r0, #0x5555             // setl all domains to client mode
  movt    r0, #0x5555
  mcr     p15, 0, r0, c3, c0, 0   // write domain control register
    *   Write L2 Cache Auxiliary Control Register
    mov     r0, #0
    mcr     p15, 1, r0, c9, c0, 2
#ifdef __ARM_NEON__
    *   Enable NEON/VFP
    mrc     p15, 0, r0, c1, c0, 2       // Read CP Access register
  orr     r0, r0, #(0xF << 20)        // Enable full access to NEON/VFP (Coprocessors 10 and 11)
  mcr     p15, 0, r0, c1, c0, 2       // Write CP Access register
  mov     r0, #0x40000000             // Switch on the VFP and NEON hardware
  vmsr    FPEXC, r0                   // Write FPEXC register, EN bit set
#endif
    *   Enable MMU
    mrc     p15, 0, r0, c1, c0, 0       // read Control Register
    orr     r0, r0, #(0x1 << 0)         // enable MMU
    *   Enable L2-Caches
    mrc     p15, 0, r0, c1, c0, 1       // Lese Auxiliary Control Register
    orr     r0, r0, #(0x1 << 1)         // enable L2-Cache
    *   Enable Caches
    orr     r0, r0, #(0x1 << 12)        // enable I-Cache
    orr     r0, r0, #(0x1 << 2)         // enable D-Cache
    orr     r0, r0, #(0x1 << 11)        // enable Flow prediction
  • Your initialization steps look fine without any problems. Do you mean after the initialization is done and MMU & L1/2 caches are enabled, your test show that L2 cache lead to some data loss? We once supported TI's CortexA8 series processor (including cache test/validation), we saw no problems.
    In addition, how about to set AP = 3, TEX = 0, C = 1, B = 1 for external RAM? This will use write-back mode instead
  • Thats correct. After the initialization you can see in my first post, I perform the data test. The test consists of 2 simple functions. First function perform simple for-loop to set test values to external RAM. Second function check in an equal for-loop the data. Pointers to external RAM are volatile to avoid optimization, so nothing complicated.
    If I change the line
    to the following
    the result of the check is ok, no data loss.
    Some interesting additional infos is, if the amount of data for the test is about 1MiB or lower, there is also no data loss.
    External Ram works fine for us without L2 in all other projects (e.G. with DSS and CAM-Module of DM3730).
    I also tried the configuration AP = 3, TEX = 0, C = 1 and B = 1, but same result.
  • "Some interesting additional infos is, if the amount of data for the test is about 1MiB or lower, there is also no data loss." - So maybe you can do further investigation per this fact.
    Assume to get a correct result,  you are doing the test with the following address scope:
    addressA -> (addressA + 0x100000)
    I think you can try to use another address scope as below:
    (addressA + 0x4000000) -> (addressA + 0x4000000 + 0x100000)
    or
    (addressA + 0x8000000) -> (addressA + 0x8000000 + 0x100000)
    The new address scope may be helpful to check if L2 cache has some bad units
  • Hi andreas,
    according to the DM3730 data sheet, L2 cache size is only 256K Byte.
    If you say that under 1MB range test is successful, the failure cause would be at the external DDR SDRAM.
    The difference between enabling and disabling of L2 cache would be the read timing. I guess the DDR SDRAM setting might be too critical. Can't you reduce the DDR SDRAM clock frequency?
    Best regards,
    Yasuhiko Koumoto.
  • I forgot to mention that the test routine already 'walk' through the complete RAM no matter how big the test data.
    So e.g. if the test data is of size 3MiB then the test write data to Adress A (3MiB), check the data, increment Adress A 1MiB and repeat the test. This loop perform until end of RAM is reached.
    So i think this kind of implementation you suggest, right?
  • Hi Yasuhiko Koumoto,
    good point. I already thought about problems of this kind.
    I have checked now a lower clock rate for RAM (from 200MHz down to 100MHz) but same results.
    I also tried to expand timings for the protocol of SDRC-module in general but also same result.
    The point why I think the RAM is maybe not the problem is, when we use CAM-module and DSS there are DMAs running to transfer the pictures from one frame buffer to another. So I think the basic functionality and internal flow is the same as with the cache module. Also an DMA will perform the load work from RAM to L2.
    Or is this wrong because the DMA for L2 is much faster than DMAs for CAM and DSS?
    best regards,
    Andreas Hauser
  • Hello Andreas Hauser,
    please let me know the meaning of "Also an DMA will perform the load work from RAM to L2".
    How can the DMA put the data into L2 cache?
    Best regards,
    Yasuhiko Koumoto.
    I am afraid that you expect the recent 256KB of refilled data into L2 should exist in L2.
    It cannot be guaranteed because the cache eviction accidentally causes.
    I hope this would be my misunderstanding.
    Best regards,
    Yasuhiko Koumoto.
  • Hallo Yasuhiko Koumoto,
    with "Also an DMA will perform the load work from RAM to L2" I would say that the preload to L2 itself would internally also be performed with something like a DMA. For me as user there is no possibility to transfer data to L2 with the DMA.
    Your second answer I do nut understand I think. What exactly can not bee guaranteed?
    Best regards,
    Andreas Hauser
  • Are you saying it checks 1MiB at a time and that the error happens when it is doing the second lot? Is there any system type instructions used between rounds if so?
    Also it might be interesting to know what the values of some wrong data are and their addresses, whether it is random data or from a MiB before or what.
  • No, if the data size for test is 1MiB there are no errors at any time. The test transfer more than 1MiB but in steps and check after each 1MiB block, see Test-Implementation below.
    The data of wrong addresses are completely random. Also the addresses at wich the error came up is random.
    For Example at address 0x8018B181 with value 0x4091A488 (should be 0x0018B181) and in an other turn it fails at address 0x80C5FEB1 with value 0xD12D1443 (should be 0xFF3A014E).
    Test Implementation:
    #define myMiB(value) (value*1024*1024)
    const    uint_32  testByte      = myMiB(256);                       // amount of test data in MiB
    const    uint_32  incrementSrc  = myMiB(1);                         // increment address in each turn
    volatile uint_32* globalSrcAddr = (volatile uint_32*)0x80000000;    // start addrress
    uint_8   inverted      = 0;                                         // inverted or normal test-data
    uint_32 copyData(void)
        /** Variablen **/
        uint_32  i;
        uint_32  testPattern;
        /** Start **/
        inverted = !inverted;
        for(i = 0; i < (testByte >> 2); i++)
            if(inverted == 0)
                testPattern = i;
            else
                testPattern = ~i;
            globalSrcAddr[i] = testPattern;
        return 0;
    uint_32 checkData(void)
        /** Variablen **/
        uint_32  returnValue = 0;
        uint_32  i;
        /** Start **/
            if(inverted == 0)
                testPattern = i;
            else
                testPattern = ~i;
            if(globalSrcAddr[i] != testPattern)
                returnValue = i+1;
                break;
        globalSrcAddr += (incrementSrc/4);
        return returnValue;
    void startTest(void)
        /** Variablen **/
        uint_32 i;
        uint_32  testResult[nmbOfTurns];
        uint_8  globalResult = 0;
        uint_32 errorCounter = 0;
        const uint_32 turns = (ram.chip->size / incrementSrc) - ((testByte - incrementSrc)/1024/1024);
        /** Start **/
        cmdPut("turns: %d\n", turns);
        for(i = 0; i < turns; i++)
            cmdPut("\nDurchgang %3d: 0x%P", i, I(globalSrcAddr));
            copyData();
            if(checkData() != 0)
                globalResult = 1;
                errorCounter++;
                cmdPut("!");
            else
                cmdPut("+");
  • I am a bit confused. The addresses should all be of words but in both your examples the addresses 0x8018B181  and 0x80C5FEB1 they are odd. The code does not include a diagnostic to output the address and data.
    I'm assuming you have just not multiplied the index by four so the first address is in turn 1 which is the second megabyte with index 0x0018B181 at address 0x8062C604, inverted is 0 and that means the value should be the same as the index 0x0018B181.
    If so I certainly can't see any pattern in it and it doesn't look like any system instructions that would cause trouble are used between turns. If cache lines were going wrong I would have expected the first word of the cache line to be wrong but it is at some odd word past the start. The values don't look like anything that would ever be generated by the program - but then again I'd be a bit surprised to see such values in ram which had never been initialisied since power up. That's very strange.
  • Oh sorry, that was my fail. you're right, I forgot to multiply the value for address by 4.
    Here is a corrected example: at address 0x814F6540 value is 0xA442962F and should be 0x0053D950. Below is the updated and corrected test-code including debug-output.
    So I can agree with your last point. I also can't see a pattern or something else. Also If the test is performed Even if the test is performed several times after each, the wrong data  are random as described above.
    Here the updated test-code:
    const    uint_32  incrementSrc  = myMiB(1);                         // increment steps in MiB
    volatile uint_32* globalSrcAddr = (volatile uint_32*)0x80000000;    // start-address for test
    uint_8   inverted      = 0;                                         // working variable for altering test mode
        /** Variablen **/
        uint_32  i;
        /** Start **/
            if(inverted == 0)
                testPattern = i;
            else
                testPattern = ~i;
        return 0;
        /** Variablen **/
        uint_32  i;
        /** Start **/
            if(inverted == 0)
                testPattern = i;
            else
                testPattern = ~i;
                returnValue = i+1;
                cmdPut("\nERROR: i: %d (0x%08X) [addr: 0x%08X | ist: 0x%08X | soll: 0x%08X]\n", i,i , I((globalSrcAddr+i)), globalSrcAddr[i], testPattern);
                break;
        return returnValue;
  • There is perhaps a pattern in the address though there's only three there. The failures you've got have been in the first or second word after a 64 byte alignment, i.e. the address ends in 0b000x00 and the cache lines are 64 bytes long. If so I could see something happening for the first word - but why should the first word be sometimes okay but not the second, now that's strange. Anyway it does sound to me that it is the start of the transfer from the L2 cache to memory that is sometimes going wrong.
    I don't suppose it will tell much - but it might be interesting to do a test where one just stores zeroes to memory and checks the result, and if that goes through stores all -1 to memory. If they do go wrong perhaps it would also make the random data that is read more meaningful.
  • Ok, I'm not sure if I really understand whats your idea with the pattern. But I can also see errors at 0x82247310 which is 0b00010000 (not match pattern 0b000x00) or 0x826D1090 which is 0b10010000.
    I also performed the test you suggest. There are errors in both variants (0 and -1). For Example at address 0x82247310 value is 0xE40B761F and should be 0 or at address 0x803FC0C0 value is 0x2B883128 and should be -1 (0xFFFFFFFF).
