Cortex M3 peripheral Bit Banding limit?
Is there an intrinsic limit to the width of the bit banding for peripherals for the
Cortex M3?
EFM32 Giant Gecko seems to have a limit of eight bits - bits 8 to 31 does not seem to work.
Is this normal?
  • Hi Hendrik,
    thank you for your summary.
    Can I confirm a thing?
    Do you say
    #define tim0_icbof0_ie *((volatile uint32_t*)(BITBAND_PERI(TIMER0->IEN,8)))
    can access the bit 8 of the IEN register?
    Otherwise, you can simply say you gave up the bit banding to access such bits as bigger than the bit 8 position?
    Thank you and best regards,
    Yasuhio Koumoto.
  • Hi,
    here is the macro I use:
    #define tim0_icbof0_ie *((volatile unsigned int *)(BITBAND_PERI(TIMER0->IEN,8)))
    then, in  the setup routine for the interrupt I use the bit banding  to access the bit:
      tim0_icbof0_ie = 1; // capture buffer overflow interrupt set
    And it just works, setting bit 8 of the IEN register of TIMER0 - if you change the int in the macro to a char, it does not work.
    So yes using uint32_t will also work.
    It makes no sense, it has to be peculiar to the EFM32 register bit band implementation, as char accesseswork for the bit banding in the ram.
    shrug
    - Hendrik
    To: H van Rooyen <shapeshifter_100@yahoo.com>
    Sent: Saturday, March 5, 2016 3:57 PM
    Subject: Re:  - Cortex M3 peripheral Bit Banding limit?
    reply from yasuhikokoumoto in ARM Processors - View the full discussionHi Hendrik,thank you for your summary.Can I confirm a thing?Do you say#define tim0_icbof0_ie ((volatile uint32_t)(BITBAND_PERI(TIMER0->IEN,8)))can access the bit 8 of the IEN register?Otherwise, you can simply say you gave up the bit banding to access such bits as bigger than the bit 8 position?Thank you and best regards,Yasuhio Koumoto.
    Reply to this message by replying to this email, or go to the message on ARM Connected Community
    Start a new discussion in ARM Processors by email or at  ARM Connected Community
    Following Cortex M3 peripheral Bit Banding limit? in these streams: Inbox
    Not interested in these emails anymore, or want to change how often they come? Update your email preferences. You will need to login to access your user preferences.
  • Hello Hendrik,
    I don't think so.
    It should be thought differently to access peripheral registers and SRAM.
    Commonly speaking, the peripheral registers are assumed by what access size can be accessible.
    In EFM32 case, the access size for the peripheral registers seems to have to be 32bit width.
    This would not be a restriction but a specification.
    Therefore, the accesses for the bit band alias area of the peripheral registers would be 32bit width. That is, LDR/STR should be used.
    From the discussion till now, I have become a confident that actual register or SRAM area access size (i.e. 8. 16, 32bit) would be the same as the size for the bit band alias area.
    For example,
    case 1:
    tim0_icbof0_ie = 1
    will act as
    1) LDR r0,[r1] // r1 contains TIMER0->IER address
    2) ORR r0,r0,#(1<<8)
    3) STR r0,[r1]
    and case 2:
    #define tim0_icbof0_ie *((volatile unsigned short *)(BITBAND_PERI(TIMER0->IEN,8)))
    tim0_icbof0_ie = 1
    will act as
    1) LDRH r0,[r1] // r1 contains TIMER0->IER address
    3) STRH r0,[r1]
    and case 3:
    #define tim0_icbof0_ie *((volatile unsigned char *)(BITBAND_PERI(TIMER0->IEN,8)))
    tim0_icbof0_ie = 1
    will act as
    1) LDRB r0,[r1] // r1 contains TIMER0->IER address
    3) STRB r0,[r1]
    I think I have completely understood the phenomenon.
    Also I have no further question.
    Best regards,
    Yasuhiko Koumoto.
