Bit 0 of PC on ARMv8-M unset in non-secure code?
The document
http://infocenter.arm.com/help/topic/com.arm.doc.ecm0359818/ECM0359818_armv8m_security_extensions_reqs_on_dev_tools_1_0.…
on page 8 says the least significant bit of the PC is used to distinguish between secure and non-secure state - and as far as I can make out non-secure state has the bit unset and secure state has it set. Surely that is rather  incompatible with the current use where it always has to be 1 and I would say most of the code would be counted as insecure? Why is the bit required anyway?
  • Hello,
    it would be no problems if existing Cortex-M codes should be executed in the Secure Mode.
    However, regarding mbed OS, it would cause some problems.
    The mbed uVisor might not be able to live with ARMv8-M TrustZone.
    Best regards,
    Yasuhiko Koumoto.
  • In ARMv8-M, there are only a limited number of cases where the least-significant-bit of the address is used to determine the target Security state; primarily these are when the address is passed to the new BXNS and BLXNS instructions.
    The existing BX and BLX instructions retain their existing behaviour, and thus retain compatibility with existing code, i.e. ARMv7-M code run on ARMv8-M won't suddenly be jumping between Security states.
    As illustrated in Figure.2 of the document you reference, the new BXNS, BLXNS and SG instructions, combined with a special return address (FNC_RETURN), provide the mechanics for calling and returning in both directions between Non-secure and Secure code. The combination of SG and BXNS form one of the many tools ARMv8-M offers to enable easier and more robust creation of secure software; the SG sets the least-significant bit of the link-register to match the calling Security state; the subsequent return via BXNS effectively ensures that the return address and calling Security state are consistent, thus providing a hardware mechanism to avoid the Secure code accidentally providing access to other Secure code via its function return (had the Non-secure code provided a bogus link-register value).
    Simon.
  • Thanks very much, I see I was getting the wrong end of the stick.
    So basically bit 0 in the PC is just referring to the use of that bit as a flag in the restricted circumstances of when possibly going between secure and non-secure state. In all other circumstances there is no difference from what happens currently.
