Context
I am working on an ARMv8-M system with TrustZone enabled. I want to completely disallow Non-Secure Unprivileged Execution (NS Unprivileged) from entering the Secure World via Non-Secure-Callable (NSC) regions using the SG (Secure Gateway) instruction.
SG
I tested this behavior on the following platforms:
Infineon PSC3M5 (ARM Cortex M33)
Musca-B1 (QEMU emulation)
The Problem
I initially thought I could restrict access to the NSC memory region using the Non-Secure Memory Protection Unit (NS MPU). However, based on my experiments, this does not seem to work as expected.
Even when a Non-Secure unprivileged process is restricted by the MPU to only access its own dedicated memory, it is still able to:
Branch/jump directly into the NSC region.
Execute the SG instruction.
Successfully transition the processor into the Secure World.
My Question
How can I properly block or disallow Non-Secure Unprivileged code from utilizing SG instructions to enter the Secure World, if the NS MPU alone isn't preventing this transition? Is there a specific configuration or architectural feature I am missing?
Any insights or best practices on how to achieve this isolation would be greatly appreciated.
Resolved. The documentation states that secure MPU is responsible for the NSC region but only if one wants to execute "SG" instruction.
Edit: actually that only means that is not possible to lock out unprivileged non-secure from entering the secure world.
Thank you for coming back to share the solution you discovered!
